Hooking up a boiler in shop
Started by busnut104, October 24, 2012, 05:46:10 PM
busnut104
Hi: need some help from you experienced electricians. What I'm trying to do is hook a coal furnace up to my oil furnace. My questions is there a relay or some type of switch that if one furnace calls for the circulating pump to run and the other also wants to send elect to the pump. I need a either or type of switch, so if the pump is running from one furnace and the other call for the pump to run the electric can not get to the pump till the other one is not calling for it to run, So the pump is not getting elect from two sources. This is not a standard hookup so bear with me. If you can help thanks.
Melbo
Pretty simple really
Same setup just the other side as when two zones call for heat or just one calls
Just do it in reverse
If that doesn't make sense I can do a schematic for you
Melbo
busnut104
Melbo: I guess if you do not mind, I could use a drawing, thanks.
Geoff
Quote from: busnut104 on October 24, 2012, 05:46:10 PM
What difference does it make if one switch kicks on, and the other one kicks on?  You are tripping the same motor.
--Geoff
Geoff
'82 RTS AZ
busnut104
I'm not sure on this that is why I asked, put it like this, if I had a motor and had a extension cord plugged in and hooked to the motor and then took another extension cord and plugged it into another outlet what would happen, would there be a direct short.
Geoff
Good point.  I have never had this "problem", but yes the 2 hot outlets on the either side of the 240 are on different waves, so  you need to hook both relays on the same side of the circuit panel.
Geoff
'82 RTS AZ
Melbo
Bottom
Bottom2
