Refrigerator problems
Started by Joebus, October 23, 2012, 11:26:29 AM
Joebus
I have a Dometic RM2852 that has stopped cooling. Both heating systems (gas and 110 AC)  are working. I have taken it out turned it upside down, gave it a bit of a shake, turned it up straight and plug it in. heat has followed up the line and across the top coil, I can hear some sort of action in the lines. But no cooling inside the unit.
There has been no smell (ammonia), everything looks as clean and dry as new. Was in last Thursday (everything cold) Sat. noticed stuff in freezer was thawing. Unit is about 10 years old
Suggestions?
Joe Beleskey ,Stroud Ont. 50 Miles north of Toronto
1977 MC8, 8V71T, Auto
Lin
Did you leave it upside down for a day or so?  I have never done it but remember that as being part of the process.  You may try calling a frig rebuilder and going over the symptoms.  They should be able to give you the good or bad news.
If both sources are working and heating check the Thermistor
Dave5Cs
If there is any yellowish powder on the tube going up the back then there is a gas side problem. It could also be the board has gone out but you would have to have a tester to check or pull the board and take to an RV repair place and have it tested. Dinosaur boards you can get on line.
Dave5Cs
Joebus
Both the AC and gas create heat. The tube up the backside is warm (95 degrees) ambient in the coach was 53 degrees. Front panel changes from auto to gas as it should.
I thought the Thermistor controlled the heat source. Is there a valve in the system that would control coolant movement
Bottom
Bottom2
