fried clutch
fried clutch
Started by ronnie32567, October 10, 2012, 08:02:46 PM
ronnie32567
1972 Eagle 8V71, 4sp man trans.  Anyone know the easiest way to install new clutch. Any info is great.
1972 Eagle conversion 8-71 dd, 4 diesel pickups, diesel tractor , diesel bulldozer  Crestview, Florida
B_K
Yup take it to Clifford aka Luvrbus aka YODA!
They look harder than they are it will take you about 5 hrs people just swing the transmission and some drop it works better with 2 people
Do you have any idea what clutch is installed now several options on a Eagle for a clutch it will cost you from 500 bucks up to a 1000 bucks depending which way you choose too go
ronnie32567
No idea about what type of clutch is in it now.  A local busnut that I met through this forum says he has an 8v71 with man trans that came out of a big military truck and that I could have the clutch out of it. I wonder if it is the same type clutch and would fit the eagle.
Quote from: ronnie32567 on October 12, 2012, 03:03:13 PM
i don't know but seriously doubt it.... :-\
It's easy to tell to just pull the bottom cover and see if it has been converted over from the pull type to a mushroom type if you live close to Tulsa I have a friend that has a fairly new button type for a Eagle I can send you his number he will probably sell it cheap,cheap
B_K
Clifford I think he's in FL.
ronnie32567
Mr Clifford, yes I live way back in the woods in florida, but UPS does run every blue moon or so. I really don't know what to look for as to a pull type or mushroom. If the clutch from the military truck wont work I'll contact you for your friends number. I have one other problem with the engine, it was completely rebuilt by Winnibego 34,000 miles ago. runs like a singer sewing machine and does not smoke at all, but when I shut it off it pours oil like crazy from the drivers side of the engine, someone told me that there was a pipe that stops up and makes it leak oil.
Bottom
Bottom2
