For The Prevost Guys With 60 Series
Started by luvrbus, October 10, 2012, 07:20:53 PM
Are any of you guys running a fuel cooler I guess it was a option on some models anyways mine had one but the fire damaged it and Prevost is very,very proud of that item is there a after market for the cooler
Living in Az I prefer to keep it cooler fuel adds hp (so I am told) then I worry about the piece of junk plastic for a fuel tank getting to hot any ideas
Boomer
Standard, not optional either add or delete.  All our newer ones had it and when specing the coach there were no options on it as I remember Clifford.  I think it was mandated  by DDC.  Hell, there was so much stuff stacked on the radiator it was a wonder they ran cool (CAC, aux A/C condenser, fuel cooler).  You might try finding  someone running a hot engine and shoot the lines with an IR gun to see what they run I would not be surprised if everything would be OK to eliminate it.  You're worried about cooler fuel gaining more HP when you are running 650 hp, lol?
'81 Eagle 15/45, NO MORE
'47 GM PD3751-438, NO MORE
'65 Crown Atomic, NO MORE
'93 Vogue IV, NO MORE
1964 PD4106-2846
North Idaho USA
Somewhere in that area Boomer lol I been around the old 2 strokes so long when the fuel gets hot they kinda get sleepy around 4 in the afternoon on a hot day
Boomer
Well, you could do like us old drag racers did 100 years ago, make a cool can with a coil of copper fuel line in it and filled with ice, lol.
1964 PD4106-2846
North Idaho USA
B_K
Quote from: Boomer on October 10, 2012, 08:42:22 PM
Yeah Boomer that was done with road racers and roundy rounders too!
(PS from personal experience "dry ice" can cause worse problems like frozen fuel!)
Hard Headed Ken
stevet903
What model do you have?  Many of the H3s and XLIIs used part number 531422 as a fuel cooler.  Prevost wants $41.91 for it.  Steve
The one I have Prevost is asking over 500 bucks for it
B_K
Clifford maybe the "Prevost Prouds" have told Prevost who you are so they are giving YOU a special Prevost Proud price LOL!  :D
You could use a Hayden cooler-just have to position it away from engine heat.  Good Luck, TomC
Mex-Busnut
Is there any advantage to adding a fuel cooler to a 6V92TA?
Jake brakes
There is advantages to adding a fuel cooler to any engine with just a single tank. Cooler fuel is denser, so you'll have more fuel injected-hence a bit more power then with hot fuel.  And since the fuel is what lubricates the fuel injectors, it can only be good.  Good Luck, TomC
B_K
Clifford I was speaking to "The Don" this afternoon and asked him about it.
He said for $500 bucks for the "Prevost part" he'd just use a "Hayden" cooler for about $40-$50 and said with their new "stack-able" design you can make it any size you want and for another $100 you could even put a fan on it!
Mine does have a fan BK, shroud and 24 v motor all the plastic melted I think I am going with 50 dollar cooler
Uglydog56
How much room do you have to work with?  Get the smallest radiator you can find at the junkyard - will already have a fan on it.
Rick A. Cone
Silverdale, WA
66 Crowny Crown "The Ark"
Bottom
Bottom2
