Need to locate a source for an oil line for a 50DN.
Started by B_K, October 10, 2012, 09:11:26 AM
B_K
Anyone have any idea where to get a replacement oil line that goes between the front and back of the 50DN?
Not long ago I read where copper lines should not be used on diesel engines as vibration causes them to crack. (the line on one of our buses must have read it to as it has cracked @ the flair and is now leaking.)
John316
These guys have rebuilt ours in the past. They should have all of the parts that are needed.
Try calling them. http://www.bctruckelectric.com/
BK, any CRES grade steel tubing like the 304,321 and others will work on the engine DD uses the 321 fwiw and most good hyd hose shops will have it
Bottom
