horn air compressor
horn air compressor
Started by uemjg, October 08, 2012, 12:52:38 PM
uemjg
I'm trying to power my 12 volt air horn and can't find a 12 volt spot to connect.  This is a 75 MCI-8.
Or am i better off getting a 24 volt air compressor?
Suggestions?
PCC
If you have 2 - 8D batteries, or other combination of 12 volt batteries to make 24 v, take a line from the connecting wire that goes between the battery/ies.
The connecting wire will be the one that goes from the positive of the battery/ies whose negative connects to the frame, to the negative of the other battery/ies. That point will give you 12 Volts positive to your compressor.
The negative wire from your compressor will then connect to the frame.
There is a 12 volt connection at rear panel I don't know about the front maybe the MCI guys know for sure but I think it is 55 or 58
thomasinnv
The mc8 had a 12 volt option which included a 12 volt lug at the front panel, AC panel, and rear panel. Stud 55 in the front, stud 6 in the AC panel and stud 41 in the rear. All on circuit #23.
Sent from my PantechP9070 using Tapatalk 2
1998 MCI 102-DL3
Series 60 12.7/Alison B500
It sounds to me like you're trying to use an air horn with its' own air compressor.  Why do that when your bus has its' own air supply.  Just buy either a 12v or 24v air solenoid and hook into the buses air system.  Good Luck, TomC
Quote from: TomC on October 08, 2012, 11:11:39 PM
     That's what I was thinkin (and what I'm doin ...)
Bottom
Bottom2
