Prevost parts cross reference ?
Started by joe, October 07, 2012, 05:08:24 PM
joe
Is there an source to cross reference Prevost part numbers?
I am in need of the air regulator and valve for the A/C and Fan gear box belt tensioners. It seems to be a single prevost part number 010588. The regulator is leaking continuously from the small diameter hole in the case and the valve leaks to the exhaust port regardless of the value position (horizontal or vertical)
I suspect I can get these from NAPA but the parts are not available to take in for a visual cross match as the coach is parked 5 hours away and I'd like to take replacements with me when I go back.
Does anyone know the supplier part number(s) for these or a way to cross reference?
Thanks in advance.
Joe
1993 Prevost LeMirage XL, 8V92TA  Allison HT-755CR
1994 Angola Conversion
boxcarOkie
It is a off the self regulator has the adjustment screw in the bottom set at 50 lbs fwiw Prevost sells the kit to rebuild for around 20 bucks but any regulator will work for you
joe
Clifford,  Does the rebuild kit include the 3 way valve or just the regulator?  I expected 2 part numbers but the air diagram just indicates a single part number?
The bigger leak is the valve but both clearly need to be fixed.
 The valve is separate, 50-0231 kit for regulator, the valve has 2 seals 50-1113 lower and 50-1114 for the upper seal (o-rings)
joe
Thanks, I'll get the parts on order. Amazing how you can answer these questions so quickly and accurately.
dickegler
Hi Joe,
mine had a similar leak, but ended up it was the cylinder orings leaking back through the return side.  Might be worth checking.
Take the non pressure hose off and see if there is air escaping at the cylinder
Dick
dick egler  atlanta, in  92 prevost/beaver conversion, N5333L
joe
Dick,
Thanks for the tip. I'll check the cylinders also. The weep hole started leaking and I changed the position of the valve. My guess is the seats are hard and now they leak - big.  18 year old coach and the rubber is going rapidly.
niles500
If the air is leaking out of the exhaust port on the valve - that is indicating that at least one of the seals in the tensioners is bad - HTH
(\__/)
(")_(")
- Niles
Bottom
Bottom2
