Will PEX pipe work in the engine compartment?
Started by belfert, September 30, 2012, 11:50:13 AM
I installed my Proheat heater in the engine compartment in the same spot the long gone Webasto heater was mounted at from the factory.  I used 3/4" PEX pipe to connect the heater to the fan heaters inside the bus.
When I stopped to check fluids the PEX pipe was pretty soft from the heat in the engine compartment.  Am I going to have issues with the PEX pipe bursting or something?  I didn't even run the heater at all this trip, but it is likely we will run it while rolling down the road in the future.  Would I be better off using copper pipe or silicone hose inside the engine compartment instead?
PCC
PEX will not burst, but it will get very soft, and maybe deteriorate and separate. (Will then look like a burst). Having used PEX all through my coach, I prefer to use copper (best choice), or run the PEX inside a metal pipe (if copper is totally impractical), when in a compartment or area where there is engine or generator engine heat.
Just my opinion.
If you used the orange color Pex you will be ok all the different grades are temperature, pressure rated I doubt there would be a problem with any grade just keep it away and off the exhaust system pressure is not going to be problem with a Pro/Heat
The PEX I used is not orange.  It is oxygen barrier though.  It is not PEX-AL-PEX because that style won't work with the Sharkbite fittings I prefer.  I did a quick Google search and some orange PEX is PEX-AL-PEX and some is just oxygen barrier.
I suppose I can use copper, but I absolutely hate soldering copper.  Maybe two out of ten of my copper joints work and I end up making the copper fitting manufacturers a lot of money.
Brian,
I'm the world's worst plumber but I've found that getting the copper really clean at the joint (Both pieces) and using lots of flux does the job. I often use way too much solder but no leaks so far!
One problem most of us amateurs have is using too much heat, once the solder starts to melt into the joint that is usually enough heat.
PCC
Quote from: luvrbus on September 30, 2012, 01:15:46 PM
I had forgotten about RF-PEX (used in fire sprinkler applications) - thank you for making sure all the info was presented !!
sledhead
Your pex should be fine it is probably rated for 180* or 200* .I use the 200* for solar hot water systems and have never had a problem.inside motor compartment should be fine just not near exhaust .I wood rent the pex crimper at homedespreat for $8. a day and use pex crimp rings more permanent (never had one leak yet)          dave
dave , karen
How much copper do you need 1/2 inch was 21.00 bucks for a 10 ft section at the supply house Friday and why Sharkbite fittings wasted money there you bus people are the only ones buying those $$$ fittings
They have new fittings for the Pex (black) 33 cents for a fitting crimp it with the stainless rings it's there for ever if you ever need to remove it cut the ring and reuse the fitting the cutter cost less than 15 bucks
I sure would not use sharkbite on hot water supply in a engine compartment
sledhead
I second luvrbus I would not trust the sharkbite,great for a quick fix but not for the long term                        dave
dave , karen
To be clear, I'm not against changing materials.  It seems almost inevitable that the PEX isn't going to work inside the engine compartment.  I'll probably have to go to copper and deal with soldering it.  I am almost certain I am getting things too hot when soldering, but I have no idea what the proper amount of heat is either.
My first go around at plumbing my bus I used Oetiker clamps.  They were used in my first travel trailer and they worked great.  I bought the special Knipex tool for Oetiker clamps and used them in the bus.  Almost every joint leaked!  Folks here recommended Sharkbite connectors so I used those and they work great.  Sharkbite connectors are the only PEX connector allowed to be sealed in a wall.  The copper rings are probably better than the Oetikers, but the tools are so darn expensive.  $70 for the crimper and another $20 for the removal tool.
I'm not worried about the cost of copper.  The only reason I would rather not use copper is the darned soldering.  That, and the fact it would take fives times as many fittings since copper is not flexible like PEX.
What would be the reason not to use Sharkbite fittings in the engine compartment?  Will the heat kill the o-ring?  They are probably all going bye-bye anyhow.
Soldering is not hard heat the copper touch the solder to pipe if the solder melts it will suck into the fitting if not apply a little heat, clean both pieces good with emery cloth till it shines and use a good flux and don't worry about building the copper up on the outside of the 2 pieces it serves no purpose that is why is it called a sweat joints takes very little solder to be leak proof
Me I just heat till the copper changes to a blueish tint and then touch the solder to pipe and go to next one
Geoff
Pex is good because it withstands the vibration in the engine compartment.
Your solution is simple:  insulate the Pex hose.  The same insulating material they sell at home depot for house pipe insulation will work on your Pex-- pipe wrap, split foam, bubble wrap, etc.
I wouldn't tear the Pex out, I would insulate it.
--Geoff
Geoff
'82 RTS AZ
You guys go know Pex sells a cover shield for the pipe you use it when bury the Pex in concrete or dirt comes in roll you slide it over the Pex and tape the ends
Insulation simply slows heat transfer.  Won't the PEX eventually get just as warm if driving long distances?  I would need to find out how much heat the pipe insulation can take before it burns.
You have a good point about copper being too rigid.  I was wondering about that since most don't use copper in conversions for that very reason.
Bottom
