rims 12 22.5
Started by disabledhunter, May 16, 2012, 01:25:04 PM
disabledhunter
Any body have aluminum rims for sale in the midwest? If so give me a call 331-684-5444
Thanks Bruce
82 MCI-9
Sean
I don't have any, but you might get more useful results if you told us a bit more about what you need.  "Rims" that fit 12x22.5 tires can be 8.25" or 9" wide, stud or hub piloted, and with at least three different sizes of bolt circles.
You might be able to use either width, but for sure you will need ones that fit your hubs and studs.
disabledhunter
Thank you Sean, did not know that information, guess I need to do more reasearch on this.
82 MCI-9
That's like some of the truck drivers that want a truck with 22.5 tires (just about all truck tires are some sort of 22.5 size-except those that run 19.5 [of which you can't get anymore because of braking issues] and those running 24.5)  Good Luck, TomC
