Power Tech woes
Started by Mike in GA, April 24, 2012, 07:26:19 AM
Mike in GA
My 10 kW Quiet Box wouldn't start, then after a few days it would. But it would shut itself off after 20-60 minutes, with no code light for overheat or low oil pressure. Plenty of fuel, and 12.7 volts on the dedicated start battery.
     Fortunately, I was at a rally with some very savvy electrical guys, and they isolated the problem to the master control module.
     Had a hard time getting PT customer service on the phone, but eventually they were helpful with a few extra tests, confirming our suspicions. The board had pooped out.
     Their parts dept was great, and shipped a new one to the rally, where it arrived quickly and installed easy. Problem solved. Runs great.
     These babies are not cheap - $278 plus express shipping. Adding to the hurt - the genny has only 1600 hours and nine years on it. Oh well...
     One of the guys who helped had suggested that we re-wire the genny to eliminate the master module. You would then have to manually prime and glow plug it, and manually hit a separate crank switch. Said they PT had manufactured the unit for years without the fancy module, but it did enable an auto-start feature, which I have never hooked up to my Trace.
     Bottom line - we will rewire it if and when the new module goes south, which I hope is never.
     Just FWIW.
Mike in GA
Past President, Southeast Bus Nuts. Busin' for almost 20 years in a 1985 MC 96a3 with DD 8v92 and a 5 speed Allison c/r.
I've heard Sean & Clifford mentioning some after market board for about 1/2 the money and not near as many problems
One of the reasons I bought the 10kw Powertech in 1993 was that all of their controls were simple Bosch relays.  I have the manual start/stop heat switch.  While I only have 1100 hours on it, the genset has had zero problems.  Just used it this last weekend in over 100 degree weather.  Good Luck, TomC
