Where to get a Clutch assem for a bus
Started by MartinD, March 22, 2012, 12:02:54 PM
MartinD
Have a friend that just picked up a 1967 PD-4107 and need everything(pressure plate, clutch, bearing, etcc)  Any ideas? Thanks
Melbo
Call Luke --- He will have it all and over night it if necessary
Melbo
PS I don't have his number with me but do a search on this site and his name will come up with the most recent number
pvcces
He can tell you all the parts that you will need for the job, as well.
I believe that you have a wet clutch, so that adds one more dimension to the job.
Tom Caffrey
Tom Caffrey PD4106-2576
Suncatcher
Ketchikan, Alaska
Dave5Cs
Keep in mind that a clutch cover can be rebuilt, and that a complete two disc clutch (cover, pressure plate, two discs, center plate) can weigh around 100 lbs so looking local is possibly an option to save shipping charges.  In my case I bought the springs and other bits from Luke and rebuilt my clutch myself.  I also replaced both the pilot bearing, the throw out bearing and the lubrication line to the throw out bearing.
MartinD
This must be a hard one to find. Luke says he is looking. Been about a month now. Are there any other sources?
Have yours rebuilt/resurfaced. Good Luck, TomC
Martin -
Try Ted Campbell at Coach Maintenance in Williams, CA.  www.coachmaintenance.com
Ted doesn't come to work until after 4 pm CA time, but does answer faxes and emails.
la chiva
hey Martin
i just pull one out of a 4905 it is brand new if you can arange transport just make me a offer
i also have the tranny . parting out that 4905 and my 4107 as a allisson 730
MartinD
Quote from: la chiva on April 18, 2012, 07:43:34 AM
hey Martin
Send you an email
MartinD
Quote from: RJ on April 17, 2012, 08:07:56 PM
Martin -
Thank ya sir :)
Like Tom I think he has a wet clutch a different animal
MartinD
