What type of disconect switch
Started by goutoe, March 13, 2012, 07:58:34 AM
goutoe
I would like to install a disconnect on my start up batteries 12 volt system on my AM general 6v92 what type or brand would You guys recommend? I installed a blade type on the coach batteries which works great but I don't think that would be heavy enough to handle starting amps. Thanks John.
John & Linda 1977 AM General 6V92 turbo Detroit 3 Speed allison, 40 ft.
rv_safetyman
Jim Shepherd
Evergreen, CO
I use the cheap green knob cutoffs from WM. They are not the most rugged but are the cheapest and most available.
I probably have 20 of them in use now including the buses and have had only one fail in 20 years.
I use one on each battery so that cuts down on the starting current load.
goutoe
Thanks for the help guys I located a switch off of a caterpillar loader I just need to build a bracket and I should be in business. Thanks, John.
