More LPG reg ?
Started by saddleup, March 08, 2012, 05:19:30 AM
saddleup
OK,got a 0-10# regulator coming, ? is should i put a 20# reg or another 0-10 set at 10# at the tank, hooking up to 30# tanks and maybe bigger, worried about to much pressure hitting the reg. i need set at 7#.
Thanks Matt
Yuma,Az
thomasinnv
pressure in the lp tank changes with temperature, regardless of tank size. a 10# tank will have the same pressure as a 100# tank at the same temperature. If you are using an apliance that uses a large volume of fuel, a larger tank is better to prevent freezeup. As the liquid expands to gas the temperature in the tank gets very cold. There's more involved than that, but you get the idea.
1998 MCI 102-DL3
Series 60 12.7/Alison B500
Uglydog56
My car runs on 4" ater pressure, one regulator.  Don't worry.
Rick A. Cone
Silverdale, WA
66 Crowny Crown "The Ark"
saddleup
THANKS GUYS,finally got this deal figured out.
Matt
Yuma,Az
