Sony monitor replacement
Started by Busnut83, February 25, 2012, 07:31:16 PM
Busnut83
What would be a replacement for the sony monitor for my back-up camera without replaceing  the camera and running new wires????
Every camera I've seen has produced a standard TV-signal type output - in Europe it's PAL but in the US I expect it will be NTSC. If your existing camera and monitor both came from Sony as a combined package it's possible that they work on some proprietary signal standard - but it's pretty unlikely I think. A generic replacement screen should work fine - just check that it's got a PAL/NTSC input in addition to the VGA (computer monitor) input. And look to see that the plugs and sockets match.
If you have the right TV run it through it I have a 20 in hooked to my Sony camera fwiw
Not all backup monitors have standard connections.  My LCD backup monitor has a non-standard connector for the cable to the camera.  The monitor also supplies the power to the camera.
I would check with www.rvcams.com to see if they have a replacement for you.
Sony cameras use RCA video cables easy to hook up to a TV the higher end RV's have been doing it since the 90's some have a switch on the dash for TV or monitor pretty sure any camera could be hooked to a TV with the right switch I've seen the Voyager camera hooked to a TV before
Busnut83
Its a gray cable with an odd shaped round plug,,, i would like to just change the monitor... sony blk&wh    ssm-721 amr is the model. looks like a small tv...
Busnut83
I just found a replacement @ RV Cams Inc,,, from Baton Rouge,La... Hope they are a GOOD company... $247.00....
Quote from: Busnut83 on February 26, 2012, 07:10:52 AM
I've had good luck with RV Cams and I have read plenty of good reviews.  Personally, I would call RV Cams to see if there is an LCD replacement instead of installing another CRT.
Yes, I'd be looking to upgrade to a LCD monitor too, especially if they're charging that much for an old-fashioned black-and-white CRT monitor. US Ebay is full of suitable colour LCD screens for less than $100 delivered. (And for another $20 you could change the camera too, then you'd know they'd be compatible. You could keep the existing wiring but might need to change the connectors).
