Flooring
Started by luvrbus, December 22, 2011, 05:35:38 PM
Any of you guys ever use the Karndean Plank Vinyl flooring in your bus comes in 36"x 3" or 48"x 7" I used it on Walmarts it is the stuff in the clothing dept that looks like wood.
I need to redo the flooring in the wife's Trek so she told me lol and this what she wants not bad in price but not cheap either with the glue just wondering if anybody here has it
How does it stands up to movement how about you Ace good or bad ,what kind of under lay would it require for mobile use and can you use other glues .50 cents a sf is seems pricey to me for glue
www.karndean.com
FloridaCliff
Clifford,
I used the vinyl plank flooring from Home Depot.
Has an overlap and sticks together like contact cement
Seems to being holding up fine.
Cliff jr  ;D
Mark Twain
Ace
Clifford, I'm not familiar with the plank your referring to but it has to be close to the same as what I deal with here under the name of Nafco pure vinyl plank. Yes I had it in my past two buses using the wood look down the center on my eagle and the ceramic look type in my Prevost! The tile looking vinyl didn't hold up after 5 or so years so I just took it upand rePlaced it with the real ceramic tile! The Nafco is a direct full spread application and is priced around $130.00 per 27 sq ft with adhesive!
We have the HD floating plank type in our house and it's good but doesn't compare to the above!
Ace Rossi
Lakeland, Fl. 33810
Prevost H3-40
