another ddec/computer ?
Started by robertglines1, November 16, 2011, 05:28:07 AM
robertglines1
When your around guys&Gals/busnuts like you it is easy to ask.   Where do you get the cable to link your computer from the usb port to the ddec port/info port.  The port I have  has 6 pins with 4 being used- is a deutch (sp)connector. Do I need to call Prevost?  Where do you buy cables to let your computer to talk/recieve from another?  Will same cable hook directly up to the ECM on the engine (DDEC IV) or do I need another.  Learning for me might seem simple for you guys.   Bob
rv_safetyman
Bob, it depends on what software you want to talk to.  Each software package needs a translator that converts the engine computer protocol (J1708 in the case of DDEC) to something it can deal with.
For example, with SilverLeaf, the cable is provided and it has a pretty sophisticated circuit board in the JIB that does that job.
If you find DD software for your computer, you will need something like:
http://www.ebay.com/itm/ws/eBayISAPI.dll?ViewItem&item=260894088055
With the Magikey, there are two different versions.  The one above is a parallel port unit.  Most modern computers don't have a parallel port.  The USB version generally goes for $500 or more.
Jim Shepherd
Evergreen, CO
Bob,I got my interface module (VEPS) for the DDDL from Detroit through Cole was around 150 bucks for UBS let me know if I can help with the interface
robertglines1
I believe a trip to Detroit (Clarke power) in our area is in order. I do have enough knowledge in hand to ask questions now. I do better one on one than on phone in this case. Seems they can see the total loss expression on my face.   I am starting to understand! Hopefully when it has sunk in it will be a moment of ---that was simple.    Thanks!
Boomer
I got mine from my Detroit distributor also.
'81 Eagle 15/45, NO MORE
'47 GM PD3751-438, NO MORE
'65 Crown Atomic, NO MORE
'93 Vogue IV, NO MORE
1964 PD4106-2846
North Idaho USA
rv_safetyman
Bob, be sure to keep us posted on the cost of the software.  The last I heard, it was pretty pricey.
Jim Shepherd
Evergreen, CO
robertglines1
least expensive non Detroit supplier: so far for DDEC IV=150.  for DDEC   VI=300.  Will be at least Friday before I get to Detroit dealer.  Bob
