4106 blinker light
Started by desi arnaz, September 26, 2011, 02:52:00 PM
desi arnaz
i have a 4106 whose blinker box went on the fritz, i replaced it with a canister type and now the dash lights do not light up when i make a turn, also the stop light light on the dash will not light as it did.  any ideas?
thomas f  Bethlehem n.h
Hobie
If you are using a small automotive type canister flasher unit, it probably is undersized.  They do make larger amperage units but my bet is it is not handling the current.  24v or 12v?
desi arnaz
i had the big blue sukka that went bad, i will replace it with a new one but i just put a small one in to check it out. seems i have 3 places for those canisters one on the e flasher knob one on the electric firewall and one for blinkers. the problem though is why no tell tale light blinking when i turn?
