Identity crisis
Identity crisis
Started by Uglydog56, September 17, 2011, 02:29:06 PM
Uglydog56
With respect to speed limits, am I a truck or a car?
Rick A. Cone
Silverdale, WA
66 Crowny Crown "The Ark"
Jriddle
IF you are talking about bus I would vote TRUCK.
John Riddle
Townsend MT
1984 MC9
Iceni John
You're an owner-operator, so you may want to drive at the speed that gives you the best fuel economy!   I've noticed around here that lots of trucks in the slow lane seem to be driven by their owners, and most trucks that zoom past seem to be driven by hired hands (who aren't paying for fuel, tires, brakes, etc.)   Besides, are your brakes good enough for higher speeds?   Any vehicle's maximum speed should be based on its braking and handling ability.   For me, life's a lot less stressful when I cruise along at about 58 MPH, and I get 1 MPG more than at 67 MPH.   The only reason I don't like the slow lane is because it's so rough in places, but if I move over one lane I feel bad about slowing the speed of traffic in that lane.
2kW of tiltable solar.
boxcarOkie
"Any vehicle's maximum speed should be based on its braking and handling ability."
Good sound advice, most of the time, I adhere to the truck limits (including truck routes) as for speed, 5 to 10 mph below posted limits.  I own the slow lane and they can have the rest of it.
If you are driving a bus ... you should not be in a hurry anyway.
I vote "truck."
BCO
happycamperbrat
Because of the slooooowww braking, I do what the big trucks do.
I assume uglydogy56 is asking specifically about legal speed limits.  My experience is that lower truck speed limits only apply to RVs if RVs or motorhomes are mentioned on the signs.  In most states RVs are a separate class legally from trucks.  A lot of the states with lower truck speed limits do it for "perceived" safety reasons.  The reality is that traffic that is all going the same speed is safer.  Truck speed limits only make sense if the roads is curvy or if there are steep grades.
There is a stretch of Interstate here in Minnesota that prohibits trucks over 9,000 lbs and also has a 45 MPH speed limit.  I contacted the Minnesota DOT and they informed me that RVs and motorhomes are allowed as they are not legally classified as trucks.  BK told me years that buses were not subject to the truck/RV/motorhome reduced speed limits in Illinois.  (Illinois recently changed the speed limit to 65 MPH for all vehicles.)
You definitely want to check on truck speed limits on a state by state basis.  Even if the signs says trucks the limits might still apply to RVs too.  I typically drive no more 65 MPH for safety and economy reasons.  I might go 60 MPH except it adds nearly three hours onto a trip to Reno.  60 MPH is a little slow on a 75 MPH interstate anyhow.
boxcarOkie
Now that is interesting.  How would one of these Freightliner or Kenworth Chassis Truck-Motorhomes be rated, RV or Truck?  Just thinking outside the box.  I suppose because of the accoutrements inside, it would surely be rated a RV, but it is 80% truck in size, shape and configuration.
BCO
Truck versus RV is all in how the vehicle is registered.  My bus has license plates that say RV right on them.  A truck motorhome would be registered as an RV however the owner's state describes it.  (Some states call them housecars or other wierd names, but they are all RVs.)
A commercial truck could not be registered as an RV to skirt the law as they don't have all the amenities of an RV generally.
boxcarOkie
Quote from: belfert on September 18, 2011, 07:10:29 AM
Yeppers, that is how I figured it.  For a brief period, I toyed with the idea of a Nascar Trailer and a truck, thought that would be the "ultimate setup" (living quarters, car inside, nice truck up front) but that brought the CDL issue to the front burner of the stove, and diabetic's cannot possess a CDL under federal guidelines as I understand it.
Just as well, it would have doomed me to truck-stops and/or Walmart for the rest of my life anyway.
BCO
In California, RV's (if not pulling a trailer or car) is considered a car.  Even if the bus has 3 axles.  You can even be in the carpool lane if you have 2 or more people with you.  Personally-I would rather see RV's under the blanket of truck speeds and rules since most buses have similar brakes to a truck (although most times bigger brakes).
Now with the new stopping distances mandated for trucks and buses under federal laws, the brakes on big rig trucks has increased.  On the front axle the brakes have gone from 15x4 to 16.5x5.  On the drive axles the brakes have gone from 16.5x7 to 16.5x8.62.  The kicker is-I talked to Meritor about their new bigger brakes and they are encouraging everyone (because of both initial and maintenance costs) to stay with drum brakes.  Meritor went on to say that the new brakes perform so well that the stopping distances come within 20ft of disc brakes.  Well-the last time I looked-most cars (including the space in between each car) are about 20ft long.  So that means if you only had the new bigger drum brakes, you'd plow through a car when if you had disc brakes you could have stopped in time.  Bottom line-disc brakes are best.  But-VERY expensive to switch over to (only about a $1,600.00 option when buying a new 3 axle truck).  Good Luck, TomC
P.S: my Kenworth truck based motorhome I'm building has been registered as a motorhome.
boxcarOkie
Quote from: TomC on September 18, 2011, 07:22:43 AM
That would be the way to do it.  A truck/trailer combo presents a host of problems for someone who is not in the industry.  I am glad that I went with the bus.
BCO
MEverard
In California, RV's (if not pulling a trailer or car) is considered a car.  Even if the bus has 3 axles.[color=blue][/color]
There are many roads and highways in California in which the signs clearly state that towing a trailer or three axles must adhere to the lower speed limit. However, my 4101 only has two axles but I generally stay on the low side anyway. I don't think it will go much faster if I wanted it to.
Mike
Mike Everard
1960 GMC PD4104-4520
Antioch, CA
Quote from: boxcarOkie on September 18, 2011, 07:21:11 AM
I very strongly considered a semi trailer with semi tractor as a rig.  The sellers had managed to get the semi tractor registered as an RV.  I drove all the way down from Minneapolis to Indiana to look at it.  My main obstacle was I couldn't get insurance on the unit.  Another issue was we would have had to cram five people into the semi tractor.
A 53 foot trailer opened all kinds of possibilities.  I was even thinking about two stories for the sleeping area.  The trailer had a ramp door built and even a lift to hold two cars.  There would have been plenty of room for air conditioning and heat.
I'm glad I got the bus instead looking back on it.  There would have been plenty of issues with being confused for a commercial vehicle.
robertglines1
Have noticed when you entered most states they state vehicles over certain weight and trucks=certain rules of road. Or vehicles of certain types.  I Try not to attract attention to my self by going to fast or to slow. As many have stated your equipment dictates your capabilities. Also your personal desires. I normally run in the sweet spot for my coach.For the 89 it is around 68mph.  It will run faster but seems to get fair mileage and good stopping feel and operation there.
Lin
I think that any vehicle towing a trailer has a speed limit of 55 in California.  I I am not sure that a toad is considered a trailer, but it probably is.
