floor tile
Started by crown, September 16, 2011, 07:50:46 AM
crown
 pros & cons on floor tile ? plus does granite tile weigh more then other tile thanks john
john
57 crown
costa rica
Ed Hackenbruch
Easy to clean, will wake you right up in the morning if you are barefoot.  ;D
Nothing like the feel of wood or carpet on bare feet.  Tile is very heavy and cold in comparison.  Good Luck, TomC
I don't understand the attraction of marble, granite, tile in a bus.  Why weigh down the bus with luxury materials that aren't designed for a  mobile platform and then worry about the cost of fuel to drag it all around?  I focus on light weight to the greatest extent possible.
Good point Bevans6. When I stripped my bus out, I weighed it.  It weighed 28,000lbs.  Now with the conversion completely done, with myself and wife in the bus with full tanks, it weighs 31,000lbs.  So I added 3,000lbs to the bus.  Not quite like some others I read about that their buses weigh sometimes pushing 50,000lbs!  With fuel prices going only up, trying to make a lite weight conversion should be on everyones minds.  Good Luck, TomC
