AD-2 Heater
Started by cjm, April 18, 2006, 01:10:20 PM
cjm
I have a Bendix AD-2 in a MCI-8 that needs rebuilding. The bottom casting has "12vdc" molded on it. Evidently, the heater wire was not hooked up when it was replaced. I would like to hook it up after I rebuild it but, if it is actually 12vdc, 24vdc would probably "smoke" it. Does anyone know how to tell what voltage the heater element requires? Maybe the impedance(ohms) of the element could be measured? Does anyone know what this value should be? I'd rather not replace the dryer if I don't have to. TIA, John
tomhamrick
You can order the bottom plate from NAPA. I just ordered a replacement cartridge for my AD-2 dryer. You can find the parts on NAPAONLINE.com.  Enter air dryer in the keyword field and press enter.
You can find the part numbers at Bendix.com.
Tom Hamrick
1991 Prevost H3-40 VIP
1981 Eagle 10
Forest City, NC
augerdogger
I have rebuilt my AD-2 and you can get 12v or 24v heaters, whatever your pleasure.
cjm
I found the info in a pdf on bendix.com. FYI, 12vdc=2.0-2.8 ohms, 24vdc(60w)=8.1-11.1 ohms, and 24vdc(120w)=4.0-4.6 ohms. John
Mrbill4108
If 12v is stamped on it thats what the heater will be.
Mine is stamped 24v for its heater.
You can change out the heater plate or just run 12v from the house battery bank through a relay if you want to control it with a 24v circuit.
Mrbill4108
79 GMC 4108A
S/N 228
Florida Space Coast
Torquester
John,
I'm not sure if the heater in the AD-2 is the same as the one in the AD-9 but if it is, the circuit will be open while at room temperature. The AD-9 unit is switched by an integral thermostat. Put that baby in the freezer before you take your measurement. FWIW this should be done each time ANY drier is serviced to be certain that they are working.
hth, Tq
Maintenance....it's a wonderful thing ![/size][/color][/b]
Torquester
1974 Silver Eagle, 3406 Caterpillar, South Dakota
gumpy
If I remember correctly, the AD-2 heater in the 8s and 9s are 24 volts and are connected to the passenger heater switch. I think that was an option, so it's likely someone added it to your coach after manufacture, and used a 12v unit. You could certainly tap 12v from the battery (probably already available in the front j-box). The schematic says there's a 3 amp fuse on the circuit, so it doesn't draw much current.
Tom Y
CJM,  I may have the bottom here w/heater if you want it for shipping as I am going 12 volt.  Tom Y
Tom Yaegle
cjm
Thanks Tom Y!  Please PM me at cjm AT chilitech DOT com.  John
Tom Y
CJM, I tried to email you with no luck. I put my email on here, its tacks@westpa.net. Feel free to email just put somthing bus related under subject.  Thanks Tom
Tom Yaegle
