Flat tire
Flat tire
Started by desi arnaz, September 05, 2011, 11:56:47 PM
desi arnaz
What is the best way to patch a hole in my steer tire?   I have a 1/4 20 bolt neatly installed in my front left tire, is it safe to remove it and plug it or do I need to de mount it and patch? I have no leak now but I suspect it will lose a lot of air when I remove said bolt.
thomas f  Bethlehem n.h
TAKE IT OFF THE STEER AXLE!
In passenger service it's ILLEGAL  to repair a steer tire that needs to be repaired the way that one does!
It needs to be vulcanized!   And with vulcanizing comes the possibility it will blow out.
I know your bus is not in revenue service any more, but seriously. Is the safety of you, your family, and others worth taking a chance?
wal1809
Quote from: Busted Knuckle on September 06, 2011, 05:20:54 AM
Ditto!!
www.snakebreaker.com
robertglines1
Is it in the tread or valley?.  If it isn't leaking it might not be that deep yet. Take  out and see if it leaks. if it does refer to above post.
AndyG
I don't think that a reputable tire shop will attempt to plug this tire for highway use.  Plugs do not tend to wokr well in radial tires.  The layers of a plugged tire are much more likely to separate.  I have had this happen on a car tire I plugged.  You may be able to have it patched from the inside and then you will have a good tire for the tag axle.
AndyG
Dad is right, make sure that it actually goeas all of the way through.  If it does, I don't think that a reputable tire shop will attempt to plug this tire for highway use.  Plugs do not tend to wokr well in radial tires.  The layers of a plugged tire are much more likely to separate.  I have had this happen on a car tire I plugged.  You may be able to have it patched from the inside and then you will have a good tire for the tag axle.
trucktramp
What BK said.  If you're gonna plug it, buy a new steer and move the old one to a different position.  A steer tire blow out is usually not a pretty thing.
Dennis Watson
KB8KNP
Scotts, Michigan
1966 MCI MC5A
8V71
Spicer 4 Speed Manual
Plugging is not even an option on these tires! Plugs are for car tires and not great for those in a radial either.
I'd take it to a reputable tire shop and have the repair it and move it to the tag or drive axle. (but if moving to drives you should have 3 more closely matching.
Lin
As above.  Just remember Murphy, "What can go wrong will go wrong".
desi arnaz
i pulled it out and didn't hear any air coming out, i will l have to go outside and check again as i just got home from a 250 mile trip to pick up a tow dolly.
MEverard
I don't like to take any chances with tires. I know that we talk about the cost of them all day long, but my life and anyone else I might kill is not worth it. Please be safe.
Good Luck,
Mike
Mike Everard
1960 GMC PD4104-4520
Antioch, CA
desi arnaz
no leak, must of gone between the tread and not much into the tire.!!! yeah!!!
Quote from: desi arnaz on September 07, 2011, 01:34:51 AM
Great news.
Now if it were me I'd find a way to mark it on the side wall that will stay a while and periodically spray bubble solution or soapy water on it and make sure it doesn't start leaking.
(you did use a guage and check the pressure while you were at it didn't you?)
eddieboy
Things have changed.  For what it's worth, I just had to have a tire plugged on my work vehicle.  Not anywhere near the weight of a bus, but, the new tire repair looks to be the only thing left when that tire does finally go.  The new way of plugging is in a kit form.  There is an end mill type of drill bit that makes the hole uniform.  The plug is in the shape of a "T".  It is put on from the inside and vulcanized all the way through the hole and to the inside of the tire.  There is also a sealer that is put on the inside after the repair is done to give the tire back the inner "skin".  With air pressure helping to hold the plug in place, I don't know how it could ever give way.  By the way, I did lose that tire recently to a wood screw.  Drove on it for 40 miles and ruined the sidewall.  It was a Toyo and I couldn't even feel that it had gone flat.  Just my two cents worth.  I wonder if the legal guidelines ever change with the technology!!
Ed Spohr/1962 PD4106/8V71/4Speed/Zion,Ill/Far North East Corner of Illinois
Butt plugs are not new..... :-*
