Front frame was a mess!
Started by Mex-Busnut, September 02, 2011, 05:32:08 PM
Mex-Busnut
Dear Friends,
Hope I am not boring you with my posts.
When we got the driver's area floor area taken up (rotted plywood), we discovered that the front framework behind the stainless steel skin was very rusty. It almost appears as if the vehicle left the factory with no primer on the framing. Is that possible?
So it was cut out and will be replaced with a newly-formed rib section.
Jake brakes
eddiepotts
Ed Brenner
Who was it that said only Eagles rust !!!   :o
Ain't nothing your welder can't fix, keep sending pics we all like to see your progress.
Thank Ed
Ed Brenner
77 Eagle 05  Murrells inlet, SC
" While We're At It " A Busnut's most costly Phrase !!
Once the steel is replaced, and if your skin is aluminum-be sure to install a rubber insulator between the steel and aluminum to prevent galvanic corrosion.  My AMGeneral bus has steel ribs with aluminum skin and is 34 years old.  Except for two small places in the exterior skin (where I expect the rubber insulator has worn through) the exterior skin is void of any corrosion bubbles.  Good Luck, TomC
happycamperbrat
I absolutely love your discussions! I learn a LOT from them! No way am I bored. And to make things even better, you almost always include bus porn even if it is the really dirty bus porn like here  ;)
