clutch
clutch
Started by berrybus, September 29, 2006, 06:09:47 PM
berrybus
we have a mci 9. we finely got it down of the jack stands after replacing air bags breaks radius rod bushings balljoints shocks and rebuilding steering box. it drove well and the breaks worked good. but i cant hardley get it in gear . reverse is the worst. it gets hung in gear to. it seems to change fair going down the road un less it hangs in gear.i adjusted the clutch in back so it didnt take both feet to push the pettle down .this didnt help the problem .what can i do? thanks jim.
"No man is a bus."
Try pulling up on the clutch pedal to make sure you only have an inch of free play.  Sometimes the pedal will get lodged in a lower position causing it to have less travel that is necessary to fully release the clutch.  Good Luck, TomC
