Bad news can be good news
Started by belfert, June 26, 2011, 04:29:50 PM
The bad news is I found one of my transmission cooler lines is worn nearly all the way through.
The good news is I'm glad I found it at home and not on the road when it started leaking or the transmission went out.  Much better to deal with it at home when there is time to fix it.  I need to figure out a way to arrange the hose so it doesn't rub against the frame rail.  The last time I had the hose disconnected I placed a piece of plastic pipe over the edge of the frame rail, but it still rubbed the hose and wore it out.
Gary '79 5C
Brian,
Good Catch !! As you said, much better to find a potential problem in the driveway. Good eyes to preventive maintenance the lines, which are much ignored.
Ocean City, NJ
It was pure luck I found the bad hose.  I never would have found it had I not been fixing an oil leak around the water pump and another one on the oil cooler.  I don't normally pull off the panels on that side of the engine.  I have the undercarriage inspected once a year, but it would have a miracle to see this bad hose.
Iceni John
A few days ago, as I was rummaging around my bus's nether regions, I saw that the power steering hose that goes up front was just beginning to touch a protruding bolt head nearby.   Yikes!   I've already once had to deal with a burst high-pressure hydraulic hose (no fun!), so I don't want any repeats.   The fix was simple  -  a ziptie and a piece of plastic hose protector, but my lesson was learnt.   Tomorrow I'll thoroughly check every hose and every cable, and hopefully have at least one less potential problem on the road.   An ounce of prevention etc etc.
Didn't someone here recently post that his bus's hydraulic hoses run inside plastic plumbing pipe, where they go along the frame rails?   That seems a good idea to me  -  maybe I'll buy some lengths of Sch.40 PVC pipe for at least my PS hose, if I can figure a way to do it without taking everything apart!
2kW of tiltable solar.
My power steering hoses go through PVC pipe at least through the luggage bays.  Dina used a weird metric size of pipe for this.  They not only run the hoses through pipe, but everything running through the luggage bays is under a removeable aluminum cover.  I guess they really didn't want luggage or cargo punching a hole in something.
Melbo
Slice the pipe open with a saw and lay the hose in the pipe and (abs is easiest) put the pipe back together to tie it into place.
HTH
Melbo
My transmission hose that needs replacement doesn't go through any pipe.  All I have is a little piece of 1/2" or 3/4" conduit I put over the edge of the frame rail to try to protect the hose.  It didn't work as the hose still wore through.
robertglines1
Might try piece of scrap fire hose for cushion . The rubber canvas combo wears well ;I use it allot on wear spots.
Why not just buy the spiral wrap from a hose supplier you can all types of protection covers for hoses,blocks and clamps they don't move to wear
babell2
Look at the installation closely. See if a length change in the hose will allow a re routing of the hose so it won't contact the frame. Now the problem is solved for ever.
Brice
1980 MCI-9 "The Last Resort" Located just south of Atlanta GA.
Just starting conversion. A long way to go!
The other Brice
David Anderson
Very fortunate find.  If you remember my post last July about my tranny hose blowing out just off Raton Pass last July, I was a few quarts from empty when I stopped.  I dumped 21 quarts of oil in my toad (pickup).  I knew of nothing being wrong.  We just happened to stop for supper and saw the oil pouring out the back of the coach.   You are very fortunate.  There are no warnings for this while driving.
David
pipopak
If the hose develops a rubbing spot is because it moves. Can it be tied tight at the offending spot with some protection at the wear point?.
Linux, when Windoze just will not measure up.
The hose is secured every foot or foot and a half.  There is a tiedown right before it heads down to the oil cooler.  I suspect part of the problem is the cooler is attached to the engine which naturally vibrates and moves around.  The hose is secured to the frame rail.
I'm going to see if I can't change the fitting on the cooler so the line can run another direction.
