Is this bolt head Torx Plus? (See photo)
Started by belfert, June 26, 2011, 08:53:43 AM
Is the bolt head in this photo Torx Plus?  I bought a set of external Torx sockets and they don't fit.
More importantly, any chances any retailer sells the external Torx Plus sockets?  I tried Sears already.  I can order online, but then I have to wait and what if I get the wrong size?
junkman42
Brian, I believe those are just 12 point heads.  Very common on aircraft particularly turbine engines.  Some call them high strength bolts!  I could be wrong because the world has passed Me by,LOL.  John L
Wouldn't a 12 point head have flat sides instead of curved sides between the points?  I did go out and try a few 12 point wrenches on them.  5/16" 12 point is the smallest I have and it appeared to work, but seemed slightly loose.  I don't have a 7mm metric to try.
I'm really worried about snapping the bolts off.  It seems like either the bolt could snap or the head could strip with the amount of torque required to get these loose.
Those are 12 point socket grade 8 bolts good luck on finding 12 points sockets I got lucky and found a set at HD their Husky brand SnapOn charges 22 bucks for one socket all the China made stuff will be 6 point fwiw.DD has plenty of those type bolts 60 series and the 2 strokes so better buy you set if you plan on working on it check you valve cover. I don't think those are 5/16 heads here is the parts number for those bolts and they are calling a 7/16 head PN 23507182
babell2
Brian I concure with junkman. Looks like standard 12 point bolt head. PB blaster, Mouse milk, ant good penetrating oil would help that situation. As far as the wrench fit, I have seen corrosion reduce bolt heads to the point a wrench won't ever fit correctly again.
Brice
1980 MCI-9 "The Last Resort" Located just south of Atlanta GA.
Just starting conversion. A long way to go!
The other Brice
I'm pretty certain they are 5/16" heads or smaller.  My 5/16" combination wrench with 12 point end fits, but it seems slightly loose.  I don't have any 12 point sockets as I have never needed them before.  I actually hate that most combination wrenches are now 12 point.  !2 point seems to make it easier to round off nuts and bolt heads.
I sprayed the bolts down with PB Blaster this evening and we'll see what happens.  I'm seriously considering having a mobile mechanic come out to remove the bolts.  A mechanic will be able to fix things if the bolts don't come out cleanly.  A mechanic isn't cheap, but a new oil cooler or oil filter adapter isn't cheap if I screw it up either.
mikke60
I have those same bolts on my motorcycle and I also thought they were torx. They were however ,as stated above, 12 point sockets. good luck.
TedsBUSted
They're also called Ferry screws, if anyone trying to search replacements.
Bus polygamist. Always room for another, especially '04 or '06 are welcome. NE from Chicago, across the pond.
JohnEd
Brian,
I have had problems with the socket getting a good grip on the 12 point bolt.  To max the engagement I ground of the recessed surface of the socket.  The part that allows the socket to slip on easily. That gave me enough bite to grip the bolt firmly.  You cannot strip a grade eight bolt.
I think the 12 point is stronger than a six if you have a 12 point wrench on a 12 point bolt in any grade.
TedsBUSted
Quote from: JohnEd on June 27, 2011, 03:57:23 AM
. . .I have had problems with the socket getting a good grip on the 12 point bolt.  To max the engagement I ground of the recessed surface of the socket.  The part that allows the socket to slip on easily. . . .
Good tip.
Also, some brands of sockets have a much sharper "corners" which give a better grip.
I have an older set of Allen brand, which give a great grip for 12-point work. Mac brand also was great for 12-point work.
Ted
I contacted a local mobile mechanic to see if they could come by and remove these bolts for me.  There answer was absolutely not unless I got the vehicle to their shop.  They have better equipment there in case they break a bolt or something.  I don't have too much of an issue with a couple hundred bucks for a mobile mechanic, but I really don't want to put everything back together and then pay them to drain the coolant and all that again.
I'm not sure what I want to do.  I really don't like the tiny heads on those bolts.  I'm afraid I could easily round off the head on one or more of the bolts.  I would much rather they were nice hex heads.  If a mobile mechanic won't do it, do I really want to tackle this myself?  I did spray down the bolts with PB Blaster last night.
You get the right socket they will not round off and I never twisted or broke a bolt on 1
junkman42
Brian, if the bolts are threaded into a casting before trying to loosen pound the heads firmly with a hammer.  Pounding does not mean as hard as You can swing with a 10 pound hammer!  A number of solid raps will greatly enhance the possibility of the bolts coming loose with out mishap. John L
Melbo
Brian if the bolts do twist off -- which seems unlikely -- there are some welders who can remove the broken part by placing a washer and then welding a "cap" or other piece to get the bolt out.
Midwest portable farm repair welders have done some "AMAZING" things for me
HTH
Melbo
