Air Jack
Started by Cary and Don, June 16, 2011, 08:50:03 AM
Cary and Don
We want to weigh the axles on our Eagle.  We have 20 ton air jacks and was wondering if there is a way to attach a gauge to the jack to do this.
Don and Cary
1973 05 Eagle
GMC 4107
Neoplan AN340
1973 05 Eagle
Neoplan AN340
Len Silva
If the jack has a gauge port, it's pretty easy.  I would use a 10,000 lb. gauge and good quality hydraulic fittings.
Use the diameter of the jack piston to get the area and use that as a multiplier.  For instance a 1" piston and 10,000 Lb load would read 7853 on the gauge.
I don't know of a way you could get an accurate reading from the air jacks since the air pressure is used to pump on the hydraulics of the jack.  Individual platform scales are made that you can put under each set of tires to read out-course these are expensive and don't know anyone that rents them out.  Easiest is just plainly drive the bus to a truck stop and use the Cat scales splitting the axle groups on the split platform scale.  The weight should cost maybe $10.00.  Good Luck, TomC
HighTechRedneck
I second the suggestion of using the truck stop scales.  I did that on a trip and it even gave me the weight of my toad separated out as an additional "axle".  Couldn't have been simpler and was only $8 (that was a couple years ago).
Len Silva
Truck scales are fine but if you are trying to set up the bogeys on an Eagle, you need to be able to weigh them in the shop.
A cheap 12 ton bottle jack with a pressure gauge works fine for that purpose.
ojgetaway32
Tractor-trailer drivers who obsess about knowing their weight in real time often use load gauges on their air bags.  It's a matter of aftermarket air pressure sending units on the bags and dash gauges.  The only problem is your steer axle is probably spring not air, so you can't get a gross weight just axle weights on the ones that are air ride.
Josh Miller, Attorney, hockey player, son, brother, friend and busnut...
1983 MCI MC9 8V71 and a 5 Speed
Wheeling, WV
If it is a HF jack you have to drill the boss on the bottom not the cylinder part but on the side where the flat boss is and tap it there check some better jacks have a plug for the gauge if you have 1 of those
In the Eagles manual they use a 12 ton with a gauge,I bought mine from these folks www.hyjacks.com but you still have to build the figuture for the jack and the wheel and you remove the outside dual to use it
