Picture Update
Started by buddydawg, June 05, 2011, 05:36:50 PM
buddydawg
Repainted front of bus and 5ft or so down each side.  I am doing/redoing it in sections.
1972 GMC T6H-5308A #024
1984 Eagle Model 10
Brandon Stewart - Martinez, GA
buddydawg
Polished Aluminum, New LED turn signals, painted bumper
1984 Eagle Model 10
buddydawg
New Mirrors
1984 Eagle Model 10
buddydawg
Sand blasted and painted rims plus new Sumitomo tires
1984 Eagle Model 10
buddydawg
Oak Entry Steps
1984 Eagle Model 10
buddydawg
More work ahead!!
1984 Eagle Model 10
scanzel
Looks GREAT from the pictures. Are you painting it outside? I just got a preliminary estimate for mine. $10,000.00.
Steve Canzellarini
Myrtle Beach, SC
1989 Prevost XL
robertglines1
Lookin good keep picture update's comming!   bob
Kevinmc5
Great start The stairs look really nice. love bus porn.
1964 4106-2471 8v71 Boise ID Driving any place I can Fit
buddydawg
I am painting it outside.  Also I have improved my technique greatly since I started.  I did not want to chemically strip it. Initially I used what seemed to be umpteen thousand ways to sand and grind especially around the rivets.  I finally found the best way to get down to metal was with a sandblaster using a 80 grit garnet which is used in waterjet machines.  The garnet is fine and uniform and leaves a perfect texture on the bare metal.  It does excellent around rivets and is not overly aggressive on the aluminum.  I primed with 2 coats of epoxy primer 2 coats of base and 2 coats of clear.  The areas where I sandblasted are absolutely beautiful, the areas where I did more with the sanding/grinding, not quite as nice.  Overall I am happy with it.  I also sealed all the seams where the metal overlaps with a product by PRC-DeSoto.  It gives it a nice smooth look.  If you look in the pic of the mirror you can see how the seam where the rivets are by the door looks.  It really takes away the edge.
1984 Eagle Model 10
jackhartjr
Brandon, you are doing a GREAT job here, looking forward to updates!
Jack
Jack Hart, CDS
8V71 Detroit
4 speed Spicer Trannsmission
jackhartjr
Everyone told me it could not be painted in sections, that it HAS to be painted all at one time.  I am glad to see that is not true!
Jack
Jack Hart, CDS
8V71 Detroit
chev49
of course u can paint in sections.. just keep things taped off and always have your paint mix the same. And its a good idea to have the outside temp and humidity the same. you can clear coat and color sand in sections as well..And the bus looks great.. However Red at the automotive paint store is really getting pricy now days...
Seville
Very nice work ! Is that an old New York Bus Service fisbowl ? They were still in service as recent as 2003 or 04 ?
I was always impressed at how well they kept them up.
Looks great now.
New York City
1984 MC9 6v92T
Brandon,
Look'n great buddy! Nice job.  Looks very nice! (even if I'm not fond of red!)
