Vin# mc8
Vin# mc8
Started by Kevinmc5, May 18, 2011, 03:23:26 PM
Kevinmc5
I'm going to go look at a 1976 MCI MC8. Can any one tell me the history? Unit # is 1327
Or do you need more info
Thanks Kevin
1964 4106-2471 8v71 Boise ID Driving any place I can Fit
Tom Y
Tom Yaegle
Ed Hackenbruch
need more info.  All of the unit numbers that are listed are 5 digits.  Google MCI Delivery List and you can search for it.
papatony
Kevinmc5
I will see the bus next week. All the the Vin # that I have been able to find for MC8 are 5 digits but checked at dmv and that's the number it is registered under. So not sure what to think. Thought some one here had an answer for that. As for the other replies Bump? Does that mean you don't like my Question or you want me bumped off the form?
kevin
Melbo
The Bump is to "bump" it back to the top of the list
HTH
Melbo
thomasinnv
the unit number would be a 5 digit number, the serial number would be a 6 digit number starting with the letter "S".  when serial numbers rolled past "9999" MCI added the "S" to the front, making it a 6 digit number.  there are no 5 digit vin numbers among the 8's. Just a few of the very first 8's had 4 digit vin's, the rest were 6 digit.
1998 MCI 102-DL3
Series 60 12.7/Alison B500
Kevinmc5
My apology to Tom y for being so rude when you where just trying to help. I'm not up to date on all the language. will look for a plate with the vin and unit # when I go see the bus.
Again thanks for all your help and putting up with and old man that understands motors bether than people
Chopper Scott
Quote from: Kevinmc5 on May 21, 2011, 06:40:55 PM
Join the crowd!!! We all are exactly the same!!   I tried here      http://www.angelfire.com/ca/TORONTO/builders/mci8.html
OK FWIW there were MCI's that only had a 4 digit VIN! (as Frank, he can tell ya all about the 4 digit VIN that doesn't exist that his bus has! ;) )
Kevin,
CK the VIN plate about the driver seat. Also the # is stamped in the back of the bus in the radiator compartment. IIRC it's on the back wall under the surge tank.
Also look behind the front bumper beside the spare tire opening upper right hand corner when looking at it.
Good luck and keep us posted!
Ed Hackenbruch
The 5 series all have 4 digit vins, same with the 6.  The 7 series mostly had 4 digits but towards the end added more. A very few of the first 8's had 4 digit vins but most are longer.  The gal at the DMV in Az. that did the out of state inspection  on my 5A had never seen a 4 digit vin before. ;D
thomasinnv
i think the issue was not wether or not there was a 4 digit vin, but was there a 4 digit unit number. The op listed a 4 digit unit number.  All the 8's had 5 digit unit numbers, and a few 4 digit vins, with most of them being 6 digit vins.  there were many many 4 digit vins prior to the 8's.  you would have to go back to the 5's or prior to find 4 digit unit numbers however.
1998 MCI 102-DL3
Quote from: thomasinnv on May 22, 2011, 02:38:39 PM
I believe if you check with "Frank" aka Slowrider you will find that his "8" also had a 4 digit UNIT # as well as the VIN! (I could be wrong, my memory ain't as long as it used to be!)
Ed Hackenbruch
After taking a closer look i see i was wrong and  not all of the 5's had a 4 digit vin.  Some of the early ones had a 3 digit vin.  ;D
chart1
I have a 76 TMC 8 with a 4 digit vin and a T 5 digit unit number
1976 MCI 8
8v71/740auto
8" roof raise
