main center roof rail mci
Started by 4shore, April 26, 2011, 02:21:24 PM
4shore
Hey guys some good friends of mine purchased a 1991 MCI c3, they put 3 roof airs on roof cutting the main rail.  I said holes needed to be reinforced with steel connecting all sides together, well they chose not to any opinions on this. thanks
This is and excellent experiment into the theory of roof hole reinforcement requirements!!
We will soon know how well MCI structures are designed to hold up in case of major damage!
Please keep us posted as the experiment progresses.
Len Silva
My guess is that in typical motor home service, it will be a long time before any problems show up.  Then they will be able to say "see "I told you, no problem".  They will probably run it 5-6ooo miles a year, over smooth highways, and the stresses will be minimal. We all know better.
Rick 74 MC-8
Not sure if its rite or not. But my 74 mc-8 had two 14" vents installed when (professionally)  converted in 1975.  The center beam was cut and no reinforcement. The only problem I have seen is the roof skin flexing when trying to seal. I have since made an aluminum frame to stop this when I installed roof warts. On the MC-8s the roof is rounded all the way side to side It now has approx 350,000 miles on it. ymmv
        Rick 74 MC-8
Previous owner installed the roof AC on the centre line and cut the centre rib.
It was cut in 1986, after being a seated coach for 11 years and having a good shunt to the front end.
No effects seen yet, but I watch for it.
I'd personally off set them if it was me with the sawzall.
