mc7 tag
Started by harpold700 3, April 01, 2011, 06:37:56 PM
harpold700 3
It would appear I have too much air in my tag. Where is the pressure regulated at?
3 dressed up as a 9
Highway Yacht
I believe mine is located on my MC-9 on the wheelwell just inside the Compressor Compartment door..
thomasinnv
should be a regulator located on the vertical bulkhead just above the rear of the engine if that makes sense.  easiest access, at least for me, is through the curb side engine access door.  Da Book says it should be 35psi.
1998 MCI 102-DL3
Series 60 12.7/Alison B500
Chopper Scott
I had to replace mine as it was leaking. As stated it's on the curbside bulkhead. Basically just north of the power steering pump. I got mine from Luke. I couldn't find a part number in my books but he knew.
harpold700 3
Thanks, checked pressure and it was to the moon, regulator fubar. Picked up new regulator will install tomorrow.  Gord
3 dressed up as a 9
JohnEd
What was your indication that the tag pressure was up?  Driving symptom?  Harsh ride?  Hunch? :D ;D
harpold700 3
Able to do burn outs anywhere, everywhere, all the time. Tag quite effectively took the load off the drivers.  Gord
3 dressed up as a 9
