Tire prices - ouch! Mistake!
Started by plyonsMC9, September 15, 2006, 02:38:46 PM
plyonsMC9
Last year, before leaving on a trip, I spotted a steering tire which was having some separation.   So, pressed for time, I had it replaced.  Didn't pay that much attention to price.  Just wanted to "git 'er done".  The tire dealer put on a Toyo tire.  Now, a year later, I want to replace the other steering tire and match it up.  $469.00 !!  Over $100 more than the comparable Bridgestone tires.  Two different distributers came back with about the same price.  For some reason, I didn't think about the consequences in the future when I would have to match up a second tire to match the other steer tire.
Oh well, if I can help someone else out by my mi$take, at lea$t it won't be a total lo$$     >:(   ;D
Best Regards, Phil
FloridaCliff
Phil,
Don't feel bad.....
I have fuel in my tank that I thought was a bargain until today....
Its impossible to predict changes in the world market....Just glad I have all new tires from last year ;D
See, you made me feel better ;)
Cliff
Mark Twain
tekebird
TOYO tires uuuused to be a value.......until they got a large demand and a following.....
My Ditributor told bme 12r22.5's in a rib are backordered and won't be in country till after the new year....unless someone had them in stock already
plyonsMC9
Yes, from the different distributers, I can only find a total of 3 - - TIRES - - in Illinois.  Not leaving me much negotiating room.
Aaarrrgh.    (National Talk like a Pirate day is September 19th)
Best Regards, Phil
Aaarrrgh, Matie
Thier she blows.....[air horns]  Iiii spotted a land lubber [bus nut]
swaaab de deck mate [clean the bus]    D map will lead us to Goold [gps route to Arcadia]
Just some fun......
plyonsMC9
Smartly done thar Nick.   ;D
And for those who can't resist ( and who would want to be resistin' something International in scope like this? ) see ye:
http://www.talklikeapirate.com/faq.html
to be startin' .
Googling  same provides will be providin'  a major amount of hits.
Avast!    :D
aaaaarrrr
Dallas
♫♪♫♪ I want to sing and dance,
I want to sing and dance.
in the "Pirates of Penzance".
Wear me silver buckle slippers and me tight shiney pant's,
I want to sing and dance!♫♪♫♪
-------Ray Stevens
JLL
IN June I bought 6 new toyos 11- 22.5 in Hood River Oregon,  mounted and balanced for $1900.
plyonsMC9
Good afternoon JLL,
Welcome to the group!
I should have mentioned, these are the bus tires,  12 R  - 22.5.  And those seem to have quite a premium.  Though the Bridgestones were about $100 + less per tire.  They had some good deals on the 11 R 22.5, but that wouldn't have matched my other steering tire.
Best Regards, Phil
Ross
Last year this time I bought 6 Sumotomo's for $260 each.  Two weeks ago the same tire was $385 each.
Ross
Craig R
What's your spare look like, Phil? perhaps it's time to stow the Toyo in the hold and  match your previous spare instead -- replace and match maybe.
Craig R
plyonsMC9
Greetings Craig!  Welcome to the board - and thanks for jumping in on this thread  to offer some advice for my tire woes.   ;D
Swapping out with a good spare,, and making it the new primary steer tire along with another new (less expensive) steer tire is a great idea.
Unfortunately in my case, the spare is, uhm, well, not very good.  In fact, I'm thinking of moving the tire I will be replacing, and making it the new spare.  The old spare needs to be taken to tire heaven now.   :D
How is it going with your engine problems with your 6v71?
Kind Regards, Phil
Hey Phil,
Here's a thought that I avoided mentioning to you as I know most busnuts are limited on a budget. But a lot of times when I find myself in your position with a "new" tire and an outrageous price on a "brand new" tire to replace it, I take one I haev and use it as a spare. Then I buy a pair of steer tires (I always try to buy steer tires as a pair, & always put "new" tires on the steer and relocate the old ones as needed), as time goes on and I need to replace drives I take the "best drive tire" and replace it as the spare then I buy 3 tires (what ever good tire I can get at a fair price) and put the "like new" spare on with the 3 new tires. So far after maintaining commercial charter buses for almost 7 years now this has worked out to be a great way of doing it. But I also know ya'll go thru don't go thru tires like we do!  But for what it's worth theres my idea! BK ;D
PS If yer coming to the "TN FALL BUS BASH @ Knuckle's" I can probably get you a good price on some Kumho's or Wahn Li's (or something like that * I got 7 of 'm on the drives along with 1 Gd Yr and no problems since MAY)
"TN FALL BUS BASH @ Knuckle's" is the place to be! Oct. 26th-31st[/size]
Craig R
Good memory, Phil, and thanks for the encouragement. Exploration of my 6V71 problem has been delayed a little while. On that same trip I noticed a seeping leak from one of my radiators. I've yanked both radiators and the surge tank and sent them for maintenance/repair; so I can't run the engine until that system's reassembled. You wouldn't happen to know where a fella could get a new lens for the sight glass on the surge tank on an MC5C, would you?
Craig R
plyonsMC9
Hi Craig,
I don't know where to find that part - If it were me, I'd post a new topic, with the heading - need surge tank sight glass for MCI5C
My guess is you would get a suggestion from that post.
You might also try your regular mechanic for heavy work - unless of course, you do that yourself.  In which case, that wouldn't help in this case.   ;)
Please do keep us posted on your progress.
Hope this helps, Phil
