Speaking of Ramco mirrors...
Started by bevans6, December 02, 2010, 12:13:24 PM
Does anyone have a wiring diagram for the Ramco remote control switch?  I have a switch, about 1" square, that has a joystick know that switches to two positions.  I didn't know if it was to control two mirrors (left and right) or to control both flat and convex glass on one mirror.
Thanks, Brian
Hi Brian,
I guess the easiest way to figure it out is to call Matt at Ramco.
Ramco Technical Support:
Matt Reverman
574-266-1455 ext. 109
mreverman@ramco-eng.com
Good Luck
JackConrad
Lets see if this works.  Here is the schematic. If you cannot see it good enough, email me and I will send it to you.  Each switch controls 1 mirrir. The center switch it to select flat or convex mirror.  I installed a separate SPST switch for the heated mirror option.  Jack
jack, that is exactly what I needed .  And I would never have figured it out by trial and error.
