BCM Forum
useable living space
Started by oldallegro, April 15, 2006, 08:34:36 AM
oldallegro
Just wondering how much useable space can be gained by moving the radiators on a 102a3 (1989 - 8v92) bus?  Can I even get an extra foot?  Is it worth the effort?  Thanks for whatever advice you all have.  By the way - how much useable space is there normally from behind the driver's seat to the back wall?  I am in Africa right now and have no way to check.
Kurt
In general, the drivers space is about 4ft. The radiators could give you almost 2 ft more if you went through the extensive redesign of the cooling system (can be done-just convert to a side radiator).  I would suggest just leaving the radiators where they are and use the space above for some sort of storage space.  Good Luck, TomC
oldallegro
So there is roughly 34' of living space from the back of the driver's seat to the rear wall.  May I also ask how much clearance there is from the top of the side windows to the ceiling?  Is it the same clearance all the way across or higher in the middle?  Thanks again.
