4104 get'n scrapped , what all should I pull off ??
Started by Bill in KS, November 26, 2010, 02:17:48 PM
Bill in KS
Heading to the scrappers place in two or three days to cut a deal on the engine / trans / radiator and 3rd member before he scraps the bus.  I'll probably get the ID plate to hang in the shop.  Mechanical condition of everything is unknown.
What other parts should I pull to have as spares or swap'n material ???
I don't need anything for my bus but I can tolerate to have some things sitting around the farm if bought at scrap price.
Bill in KS
PD4104-4797 in SE Kansas
uncle ned
Every thing that is removable,  sooner or later the group of 4104 owners will need it.I don't know of a owner that would sell their bus till they get to old to drive. Most of us end up with several just to keep them from getting them scraped.
If it was closer I would go with you and get the whole thing.
uncle ned
4104's forever
6v92 v730
Huggy Bear
Bill in KS
Hey
I understand and agree.
I've only had my bus for a few months and haven't felt the pinch of not being able to find " that part " so I thought I'd throw it out on the board for some ideas.
I have plenty of equipment to handle any of the parts off of the bus.
Bill in KS
fe2_o3
   Does it have an alt. or gen? Good voltage reg?(expensive when stuck out in the pucker brush). Are the brake drums, s cams good? Drive lines (yoke)? Exhaust manifold(s)? Clearance lights? (usually right side) Amber and red bullet lights. Rear or front glass?
   Just some of the things I've had to hunt down over the years. Once it's scraped they're gone...I understand, but still it's sad...Cable
Sofar Sogood
1953-4104
KB7LJR
Everett, WA.
Ed Hackenbruch
uncle ned
If it has the original rear glass    pure gold
uncle ned
4104's forever
6v92 v730
Huggy Bear
gmpd4104
rear glass
marker lenses
any good bay doors ( can be taken apart later)
entry door
engine doors
radiator if good
Governor assembly
Bumpers if good
Really anything you feel lake taking off and storing if it is in good shape....
Rick59-4104
 Bill,
If the second cargo door in front of the rear wheel well on the drivers side is in good condition I would be interested in buying it.......I also need and would buy the parking brake assembly that goes on the driveline just ahead of the transmission, someone removed mine I guess when they put spring brakes on but it would be nice to have....
My cell is eight-seven-zero-416-sixty-four twenty if you need to discuss the parts I am looking for....
Rick
NW Arkansas
1959 GM 4104  No. 4115
1972 Grumman Kurbmaster Stepvan Conversion
1957 Airstream 13 panel Overlander
Bill in KS
divinerightstrip
The Bus Girl
sweeney153
Bill
I am looking for the panels between the side windows.
Kevin
Warwick NY
1964 4106-2703 8V71 Spicer 4 speed
fe2_o3
Sofar Sogood
1953-4104
KB7LJR
Everett, WA.
Rick59-4104
Hello Bill,
Thanks for calling, I just double checked it is the second bay door in front of the rear wheel well, drivers side I need...The door in front of the battery compartment.
Rick
NW Arkansas
zubzub
If it's not too late, the upper hinge post for front door, that is inside the body, held on by three bolts, blind removal with a socket wrench but doable.  also the steering wheel horn contact internals (lost mine)
bigjohnkub
Sounds like time for a tear-down rally at your place.  All with same model could come and help tear apart and pay their portion.
Big John
Big John  Tyler Tx PD 4903-188 & 4107
871 dd, 4 spd Fuller.
LOVE MY BUS!!!!
9035304497
