bendix part numbers
bendix part numbers
Started by thomasinnv, November 24, 2010, 09:24:52 PM
thomasinnv
can anyone tell me the bendix part number for the E6 brake valve for a MCI 8?  I see several E6's on ebay pretty cheap.  Also I am looking for some aftermarket part numbers for a bogie slack adjuster and brake liners.  I have a parts manual but obviously buying from MCI is VERY costly for these items.  I see lots of parts out there much cheaper than MCI but want to make sure I get the right parts.
1998 MCI 102-DL3
Series 60 12.7/Alison B500
thomasinnv
1998 MCI 102-DL3
 Derric aren't all E6 valves the same only the mounting plate is different and I was thinking the E6 is for a dual air system the slack adjuster should not be a problem to match Ryder fleet or Anything Truck should have pictures and numbers for you not that much to choose from on slack adjusters, not much help to you as you know I am not a MCI guy
robertglines1
I just went to my local brake supply house and they fixed me up with a rebuilt about $90 If I remember rite (on a Mci 8  1978) Bob
thomasinnv
Thanks guys.  Clifford, I assume then that all E6 valves are the same and I can just use my mounting flange on any new E6 valve?  I find them on the e place as low as $20 for a new one in box.  Mine is leaking air, I can hear it hissing when you hold the pedal down.  And yes, MCI went to a dual air system in mid production of the 8's starting with unit number 31843 according to 'da book'.
As for the linings, MCI parts supercedes the part number to 'EX4398D' which is an 8 pack of linings.  I found 4398D at this link http://www.finditparts.com/t/manufacturer/fritec/p/fritec-4398d-dot-937-bn4 which appears is just a set of 2 for one wheel, at around $22.  Look right to you?  I have 1 broken on one tag is why I'm only replacing one.  All the linings are like new accept the one that broke.
as for the slack adjuster, I could find no other part number through MCI or elsewhere, so I will just crawl under there and see if I can find a part number on the slack adjuster and go from there.  Otherwise I suppose I will just have to pull it off and match it up at a parts house.  I was hoping to have all the parts in hand and only have to block the bus and get dirty one time.  I prefer to have all the needed parts in hand when starting a project, but that can't always be helped.  Especially on these buses.
1998 MCI 102-DL3
Len Silva
On something as critical as your brakes, I would be very careful with eBay purchases.  The first thing that comes to mind is a Chinese counterfeit part.  They are everywhere and your life could depend on it.  Brake parts are just not that expensive at legitimate sources to take a chance.
thomasinnv
Quote from: Len Silva on November 26, 2010, 10:29:12 AM
agreed.  However, the ones I was looking at were bendix name brand.
1998 MCI 102-DL3
Len Silva
That's fine as long as you trust the source.  Just because they say Bendix on them doesn't mean they are not counterfeit.
Slow Rider
Thomas I was discussing your problem with another bus nut and he asked had you checked to see if one of your diaphrams was leaking.   He said if one is bad you can hear air from the valve.  Have you checked them?
Frank
The MCI has landed..... We are home.
Dale City Va.  Just a southern suburb of DC
Yes I am a BUSNUT
1976 MCI MC8
thomasinnv
Quote from: Slow Rider on November 26, 2010, 05:41:32 PM
Frank
No, I haven't.  The thought never occurred to me.  When you say I would hear air at the valve I assume you mean that I would hear the air going through the valve on it's way to the leaking diaphragm?  It actually sounds like air leaking out of the valve itself.  Before replacing anything I will have the wife step on the pedal and I will verify where the air is actually leaking out of the system.  I don't want to throw unnecessary parts at it if not needed.  Thanks for the suggestion, I will take it!
1998 MCI 102-DL3
gmbusguy1
Just call Luke at US Coach he has the knowledge and parts you need at fair prices and best of all the advice is priceless and correct
Chris
