Universal electric pump for priming.
Started by rampeyboy, November 22, 2010, 12:28:30 PM
rampeyboy
Hello guys, My bus has lost prime, and I was thinking of using an electric pump to prime the engine. Should I be concerned about the electric pump damaging the gear driven pump? Why do some of the cheapo electric pumps specify to not use with diesel? I would think it would pick up any liquid provided it wasn't too thick??
Boyce
Boyce Rampey
Columbia, SC
Scenicruiser 227
Quote from: rampeyboy on November 22, 2010, 12:28:30 PM
Boyce
Boyce,
I can not say 100% that the reason for certain pumps saying not to use with diesel. But my guess would be because diesels usually require high pressure and many of the elcheapo's can not do the required pressure. Thus they tell you not to use them with diesel so they don't have to honor returns for the retards that try it anyway!
For what you are talking about it is fine to do. as your not planning to run the engine off this pump, but rather just provide fuel to the existing pump for priming situations!
Of course there are simpler ways to do it with out an installed pump as well! Some use garden sprayers and I personally like the dish soap bottle method!
Boyce, Auto Zone sells the inline flo through diesel electric pump for around 70 bucks buy the 3/8 pipe size and don't use the mickey rat filter that comes with install it in the line and forget about it no need to do all the bypass valves has worked good for me over the years
I can't think of any way a simple generic fuel pump can harm the mechanical fuel pump. I used one the last time (Only time) I lost prime and it worked fine.
Iceni John
When I inadvertently introduced air into my fuel system and lost prime (Doh!), I put in a $50 Facet-Purolator pump that's plumbed and wired in parallel between the Racor and the fuel pump.   Flip a switch and close a valve, and in less than a minute you're on your way.   Once the engine's running, close the valve and turn it off.   Easy.   (The valve and fittings ended up costing more than the pump!)
2kW of tiltable solar.
Len Silva
Here's how I did mine, inexpensive generic fuel pump.
muddog16
Here is a diagram for a fuel priming system.
Pat
1982 Prevost LeMirage
8V92TA/HT754
You don't need to do all the plumbing Pat a flo thru inline pump works without all the valves and fittings
Clifford, you forgot to mention the built in check valve.  ;) ;D ;D I'm gonna put a couple of valves on mine, just cause they look cool! ;D ;D
I was thinking about plumbing one in parallel also but have to agree that series with flow through valves will work just as well and much easier to plumb.
My guess is that all electric pumps will allow flow through, anyone think otherwise?
pvcces
Gus, if you check the pressure required to open the DD check valve, you will see that the pressure drop across it is very low. I discovered this when I was trying to run down why I wasn't getting the fuel pressure delivery the engine book calls for.
We changed the filter, replaced the fuel line, the fuel pump and the pressure was still low. Then, we found that the check valve had a faint crack in the side of it.
We changed that out (it was around the price of a new fuel pump) and the pressure was just shy of the spec. in the manual. When we started out, the pressure was about half of spec.
I finally concluded that the long run in the bus, compared to other applications was leading to a pressure drop at the engine. We left it at that and we have had good fuel economy and power and no fuel delivery problems since.
I would not put an in line fuel pump without being sure that there was enough delivered pressure.
For what it's worth.
Tom Caffrey
Tom Caffrey PD4106-2576
Suncatcher
Ketchikan, Alaska
rampeyboy
Thanks for all the tips guys. I think I will look into that flo through pump. Putting it inline in a permanent manner may be best. I'm thinking that may be a good back up in case the mechanical pump quits. It looks to be tough to change, particularly on the side of the road.
Boyce
Boyce Rampey
Columbia, SC
Scenicruiser 227
Just so we don't get to far off here Boyce the in line flo thru will not supply enough fuel or pressure alone to run the Detroit above idle it is only to prime and does not affect the gpm and pressure of the gear driven pump and you are right the fuel pump is a bear to change,I can post the parts number for the Airtex flo thru pump with the check valve if you like fwiw the pump cost less the than check valve from DD
rampeyboy
Does the check valve come with the pump or separate? I would appreciate the part number if you have it handy, that'll save a little leg work!
Boyce
Boyce Rampey
Columbia, SC
Scenicruiser 227
Tom,
You and luvrbus have me going now, he says it works fine for him and you have doubts!!
I can understand that the check valve in a series pump could restrict the flow somewhat but if the pump inlet/outlet is larger than the fuel feed line wouldn't that compensate for it?
Also, why not eliminate the check valve at the primary filter and use the series pump check valve instead - no need for two check valves.
The stock DD check valve is suction operated. If you have a leak between the tank and check valve or in the check valve you will take in air and lose suction. This could explain your original  low  pressure drop across the check valve.
This is a really long supply line for a suction system.
The good part is if you have a supply line leak you don't pump out fuel.
The bad part is if you have a big leak you will fill your engine fuel system with air!!
