What's on your wall.
Started by chuckd, November 15, 2010, 12:53:38 PM
chuckd
Yes, shorty has some very nice "plush" carpet on his wall. Doesn't it just make you want to go disco dancing?
chuck
eddiepotts
Ace
We have paintable wallpaper (but hasn't been painted) and cherry laminate with round corners thru-out.
Ace Rossi
Lakeland, Fl. 33810
Prevost H3-40
happycamperbrat
I have bright silvery OEM stainless steel with a few places of glue that needs scraping and misc stuck pieces of early 1980s style yellow foam insulation  ;D
One day I will have walls that will be cool. I have some 4x8 African Mahogony in 1/8" thickness and I have paintable wallpaper....... One day, all this will go up. It is a step at a time, and for me there seems to be lots of time in between the steps.
I love the blue rope lighting, and the carpet is really good for sound deadening and insulation purposes, and Ace's looks so elegant!!
eddiepotts
The blue lighting really helps at night while driving. I don't have to close the curtain to block the glare from the windshield.
robertglines1
We use quilt batting on wall covered by upholstery material.lots of choices in design and color also easy to update..3rd coach this way . nice soft touch and sound deadening..Bob
happycamperbrat
That's another thing I have TONZ of is quilt batting and upholstery grade deep blue velvet. I need to get some time to finish stripping, Im getting help to put the bus in the air and do the work needed underneath, then I gotta finish stripping. I also gotta put up insulation which I think I am going to use the bubble tin foil stuff because the spray foam is expensive and the styrofoam would melt in a fire and I think that with 2 layers and an air gap inbetween that the bubble tin foil would be just as insulative if not more so then the other 2 choices. The wiring and plumbing will be in channels outside the walls for easy maintence and I guess I will have ductless air cond and heating. Im still confused about painting the inside of the coach with ceramic paint stuff before I put up the insulation..... I may or may not do this.
robertglines1
in a fire the fumes (poison Gas) from furniture would get you first long before the plywood over the insulation burned thru.the R-factor on the bubble is next to nothing. compare r-value and cost.Another discussion but it is very important considering the extreme temps you will be using your coach in..Good luck Bob
happycamperbrat
Thank you Bob for the info both in PM and here. Im back to the drawing board. I would rather not gas my family which is why I was staying awaying from the foam board. Yes, this insulation is for another discussion. When Im ready to actually do the work I will post a thread about it.
I'm a long way from needing it yet, but I bought a roll of commercial-grade fabric wallpaper from Ebay for my bus. It's the sort of stuff you see in the lobby of hotels and so on - very plush, but also very durable. Being fabric-based it's quite thick and is impossible to tear (I've tried), so I think it will be ideal for the bus. The roll I bought was huge, so I think 95% of it will be going back on Ebay when I've done.
