Fridge maintenance.....
Started by Iver, November 09, 2010, 12:23:04 AM
Iver
Our coach has been sitting for quite a while lately while I continue working on it.  With the winter season coming it won't likely
get used until next year.  I sort of forgot about the fridge.  It is a elec/propane model and I guess I haven't turned it on for a year.
Should these fridges be run occasionally?  How often? Or are they okay to just sit indefinitely?  I usually keep the doors open a little so it doesn't
get stale inside.
   Thanks,  Iver.
Abbotsford, British Columbia, Canada
"Life may not be the party we hoped for,
But while we are here we might as well dance".
I don't do any particular maintenance, but the propane chimney seems to rust, so it's good to inspect/rectify that area before starting up again if it's really been a while.  Keep the doors cracked open to reduce mold growth.
John Z
It won't hurt to stuff them full of crumpled up newspaper. Keeps them from getting smelly over the winter.
www.silverbrook-mn.com
mikelutestanski
Hello:    Read the manual . You should clean and inspect the burner assembly 1 time per year to keep the rust particles from clogging the burner tube..
    Search the archives we had a post on that a while back.
   FWIW   regards    mike
  1972 MCI 7
  L10 Cummins  B400R  4.625R
When you get tired of trying to make the absorption refrigerator work, check out the NovaKool 9cu/ft refrigerator.  It runs with a Danfoss 12v compressor (like your house refrigerator).  It pulls 5 amps when running, so with 50% running time, a total of 2.5 amp/hours.  The 9cu/ft is a bottom freezer, and has the compressor in front so that venting is not an issue.  Costs about $1,800.00.  Runs on either 12vdc, 24vdc, or with an optional built in inverter 120vac.  It is the refer I'm using in my truck.  Good Luck, TomC
