BCM Forum
Repower MC9 Conversion from 8V71
Started by arl, October 24, 2010, 06:27:49 PM
Melbo
Just as a heads up -- I only get about 7 mpg --- drive it fast and 6.8 --- drive it slower and 7.2
I did not figure I could pay back the repower from the fuel mileage but because I didn't have to rebuild the two stroke and change the tranny to auto
I would have spent the same money to upgrade and keep the two stroke.
YMMV
HTH
Melbo
I spent a lot of time researching a swap to a Series 50.  I spoke to a number of people who had done this.  It needs a new differential gear or a high overdrive gearbox, or both, and the average timeframe for the physical install was around 45 days of actual work, whether bought out or done by a highly skilled owner.  The cost was estimated $15K to $30K, not including a transmission.  For me the biggest issue was going to be getting the computers talking to each other and to the bus...
I decided 3 mpg wasn't worth it.  People who had done it uniformly praised the change.  I guess I decided that if I wanted a bus with a 4 stroke, I would just buy one and be done with it.
rv_safetyman
Alan, on this and BNO, you have been given some pretty good advice.
If you are SURE that your engine is toast, I would do a rebuild since you have the ability to get it done inexpensively.  The engine is easy to remove and your boys can work on it a lot easier when it is out.  Again, make sure that your engine is, indeed, toast and is not just leaking or using oil because someone stuck the wrong oil in it.  As you probably know, you can inspect the cylinders without tearing down the engine.
Then, stuff it back and and drive it while you do your homework on a four-stroke. You can recoup a significant part of your rebuild cost when you replace the engine by selling your 8V71.  Keep good records and take lots of photos so that you can document the rebuild.
After you do your homework - take your time - you will make a good decision.  20-30K per year begins to add up in terms of fuel savings.  I estimated in my article that I saved about $4K in 50K miles of driving.
Since you have a clutch already, then a truck transmission with overdrive makes good sense when you go to the four-stroke.  Better yet, the AutoShift is also a good way to go.  I really don't think an OD will do you much good with the 8V71, as you need to keep it wrapped up.
Jim Shepherd
Evergreen, CO
Jim, it is not funny but I had to laugh your 4000 dollar fuel saving went by/by with all the problems you have had lately your in the hole buddy.
If the guy doesn't like 2 strokes best for him to get something else he will never be happy that is the reason most of the 2 stroke people don't waste their time responding.
rv_safetyman
Clifford, good talking to you today.  Yep, by having to get the second Series 60, my savings were overshadowed by the costs involved.  Maybe I could look at it as paying for most of my replacement engine  ;D >:(.
My gut feeling is that the 6V92 would have been a problem if I had put a ton of money in the rebuild and then tried to have it pull 46K pounds up these CO hills (service truck is 9.6K).
I talk a little about buying an engine in my article.  I made a huge mistake believing that Series 60 engines were all  "million mile" engines.  I worked with statistics much of my working life and should have understood.   My engine had over 650K miles and I had a very uneasy feeling.  At the time, it was about the only engine available within a reasonable distance.
Southern Oregon Diesel got bitten several times by installing used engines in buses.  As I understand it, they would only install engines they rebuilt after they got bitten several times.
The issue today is that everyone wants to avoid four-stroke EGR engines.  That dictates engine prior to about 2003.  It follows that these engines have a ton of miles on them.  Not a good situation.  I have suggested to a couple of folks that the consider getting a salvage engine and have it rebuilt.  Hard to justify the cost when you only put a limited number of miles on in a year.
For my second engine I was fortunate to find an engine in a wrecked truck where I could verify that the engine had be rebuilt (220K miles previously) by a DD dealer (got receipts from both the owner and the DD shop).  Even that does not guarantee that I will not have problems.
Because I did all the work myself, I am not out much more than it would have cost to rebuild my 6V92 that spit up (at DD rebuild cost).  Having said that, if I paid myself $5 per hour, the conversion would have cost me about a million dollars  ;D ;D ;D
Jim Shepherd
Evergreen, CO
Rebuilding you're 8V-71 will be the best and cheapest way to go.  Once overhauled properly, you'll probably never have to do another over haul again-suggest you restrict your injectors to N60's for best fuel mileage and longevity.
Another way to go is to find a crashed trash truck with a Cummins ISM and Allison world transmission. Buy the whole truck (make sure it hasn't been pilfered) so to get all the wiring and parts for the electronic engine and transmission.  Then you'll have an engine that will get 8-10mpg and and enjoyable automatic transmission to drive (I drove 1.3 million miles truck with 13spd transmission-I have Allisons now).  Good Luck, TomC
RoyJ
IMHO, a commonly underestimated engine is the little Cummins ISB, specifically the latest 6.7L. Without the emmissions crap, they'll happily make around 400 hp and 800 lb-ft of torque.
Now, they'd never stand up to commerical duty cycle at those power levels, but for an RV, it's perfect. The best part is, they're everywhere in junk yards from late Dodge HD pickups.
The only think I'd be worried about is the 68RE transmission. They're fine for the Ram's 26,000 GVW, but on a coach with 36,000 GVW, I'd spend a grand or 2 beefing it up and add a big cooler. That said, hot shot haulers routinely gross 36,000 stock.
You'd have to gear the diff to run about 2000rpm @ 60mph. Which requires roughly 5.13 on a 42" tire. By doing so you'd have a passing gear (5th) of 2600rpm@60, and hill climb (4th) of 3000rpm@60, with a whole bunch of gears for lower speed - a lot better than the stock 8V71, especially at altitude.
You'd easily get 10mpg with this setup, and have minimal cooling requirements.
arl
Roy,
   I don't doubt your word, and if you're right, I'd be very interested to pursue your suggestion.  But I have a few questions:
1.  Is the ISB a 2-stroke?  Why the high rpms?  3000?  That sounds high, even for me, who is used to 2300 rpm cruising speed at 64mph.  I thought THAT was high.  The poor 8v71 sounds like its hurting itself.
2.  10mpg is my dream goal.  Are you just shooting from the hip or is that really possible?
what do the rest of the board readers say about this?
thanks!
Alan
The ISB is the dodge ram pickup truck engine.  it's a good engine but it makes its power from rpm's not raw displacement.  I wouldn't put one in an MC-9 on a bet.  It's OK up to maybe 25,000 lbs and slow, you'll be 10K over that and you already think the 8V-71 is slow.  All that said, you can over-fuel the thing to death and get 400 or even 600 hp from it, for a little while!  Mind you, I think it's the best pickup truck engine every created, and the earlier versions were even better, for pickup truck use...
ISB 5.9 L
ISL 8.3 L
ISM 11 L
The ISB is not going to cut it in a 40 ft bus
robertglines1
reason I ask where you were is their is a preowned engine guy in Central City-Ky he also does rebuilds       Bob
arl
OK. I hear the cautions about the ISB (5.7 L) not being big enough.
So what about the ISL?  I have a friend who has one with an Allison world transmission in a wrecked country coach RV for $7k, not including controller/remote.  I could probably get it for $5K plus the controller (which will then require programming as well) for another $2K.
Is that reasonable and doable?
robertglines1
8 v 71 = aprox 9 ltr   61 cubic inches per ltr  568 inch in 8v71
I would personally stay far away from an ISB.  They put out a lot of HP, but not a lot of torque.  Stock they put out less torque than an 8V71 I believe.  A Series 60 puts out around 1,350 lbs of torque and up.  Torque is as important as HP in a large vehicle.  Remember that 26,000lbs is the maximum load for a pickup pulling a trailer.  It is very rare for most pickups to be loaded that heavily.
Diesel pushers used to use a lot of the ISB, but now they mostly use the ISC or similiar and bigger.  Freightliner uses the ISB in their diesel puller today, but that is about it.
RoyJ
I knew I'd open up a can of worms with the ISB. Think about this: thousands of 40' school buses, grossing 30,000+, run around everyday with ISBs tuned to mid 200hp (for commercial longetivity).
Now, put on 5000 lbs more, but add 150hp, and suddenly it's not possible? A lot of people doubt it simply because it hasn't been done, not because it isn't possible. The MCI 102 I drive at work dynos 290 rwhp with an 8V92, nobody ever doubts its ability. Now, put in a 350 rwhp ISB, and all of sudden it's big no-no?
Yes, there is one catch - you'll have to run high rpm due to lack of torque. But compared to what? An ISM? Sure. But 8V71N? which makes what, 900 lb-ft with common injectors?
Remember, toque can always be made up from gearing, but hp always remains constant (law of physics). As long as you're making the horsepower needed at the crank, gearing will ensure enough toque is available at the rear axle. This is why I stressed the importance of a 5.00+ gearing.
