Tow system parts list
Started by Devin & Amy, August 28, 2006, 06:46:42 AM
Devin & Amy
Hi all,
OK, I need a list of the parts and pieces to put together a 4-down tow system for a 2000 ford Excursion 4x4.
I will be going the driveshaft disconnect route as it seems to be the easiest to operate.
I need to learn about the braking boxes that sit in the vehicle. Do they need bus power or are they reliant only on the toad for power?
i will probably be using magnetic lites with 24v replacement bulbs in them.
any help appreciated.
Devin
Devin, Amy, and the kids!!
Happily Bussin'!!
Devin,
I thought the Excursion was able to be towed without driveshaft removal in the 4x4 model??
Devin & Amy
Nick,
The demco site has the specs for a disconnect to be required.
i think this is due to the electronic shift on the dash, which has no neutral for the transfer case.
i would rather not buy the disconnect, is anyone else towing a 4x4 with shift on the dash?
it is an Automatic, V-10, 4x4.
Devin
Happily Bussin'!!
Devin,
Only the GMC's and Chevy full sized SUV's are towable without all that extra work.
My GMC Yukon has a push button with nutral... My Jeep is also the same.
DrivingMissLazy
My 99 Tahoe has the pushbutton with neutral also.
Quote from: Nick Badame Refrig. Co. on August 28, 2006, 08:16:18 AM
Devin,
