Detroit 6v92T set up
Started by eagle10, August 27, 2006, 05:46:11 AM
eagle10
Would I run into any issues if my 6v92T were set up from 2150 to 2300? Ideas?
DrivingMissLazy
I run the 8V92 in my Eagle 10 at 2300 rpm for at least 100,000 miles with no problem. This was full load governed rpm. I seldom run it that fast, but did run in the 2200 rpm up a lot of grades. I do not know what the top speed was but I could bury the speedometer at 80 and still had more left.
Quote from: eagle10 on August 27, 2006, 05:46:11 AM
Happycampersrus
It won't cause any problems. The only time you would have to worry is if you were to go much above 2500.
Dale
