Feedback from old board post
Started by NewbeeMC9, August 21, 2006, 06:02:56 PM
NewbeeMC9
before the board was upgraded to this fancy-shmancy :D board.  I had asked a question about getting smoke when flipping on the Jake brake or givener pedal while the jake was on and getting a puff of white smoke.  I had many wonderful replies from the greats, I believe Luke even responded,  recommended running the rack if I remember correctly.
I drove over the same mountain so I have a chance to share an update.  It didn't smoke this time.
here is the difference:
- warmer outside, 70's and misty, around 30 last time
- At some point I remember to get additive when I filledup.  I had been out for a little while on my old f250,  I run alittle tran fluid mixed in and it keeps it running smoother and smoking less.  so i bought some lucas because thats what they had and put it in(no trannyfluid because of the dye).  I probably still need to run the rack and I am not making any suggestions or rebuttals.
I'm just sharing what I did and the response i had by doing what i would have done anyway.  YMMV (we need a smilycon for this)
I learned where the valves are and may run the rack in the fall when I can set aside time and partly because I want :-\
gotta love the bus ;)
8)
NewbeeMC9
Came back over the hill again, seemed to use less fuel too,  I watched for smoke and took it easy on the big hills as usuual.  another note that has changed is that the place I get fuel has Biodiesel now,  It doesn't say B20 some I"m not sure if thre is a mix.  He is $.14/gal cheaper than the station across the street.
Do ya"ll run fuel additive?  if so what's your practice? are there nay sayers?
Just interested. ???
8)
plyonsMC9
Hi there NewbeeMC9,
I've never run an additive.  I seem to remember some folks with a lot more knowledge on the subject detailing why you should not run an additive.  Also, I believe in some of the docs from Detroit Diesel that fuel additives were declared not a good idea.  And in fact, may void warranties.  Of course, with my old 6v92, that is NOT an issue.   :D  At the same time, if the engineers at DD thought they were a bad idea, that is good enuogh for me.
Just my 2 cents.
Hope this helps, Phil
