102C3 'door open' light stays on and fuel filter question
Started by ChuckMC8, July 02, 2010, 08:10:12 AM
ChuckMC8
Hi All,
I'm doing some maintenance on our church bus, its a 93 102C3 with a 3176 Cat engine.
It has a couple issues that I need help with-
It has the 'door open' indicator lamp on the console illuminated. Which doors are signaling the light? All bay doors? Just eng doors? where are the switches on the doors?
And... I want to change the fuel filters. The bus is on a road trip today so I cant have a look in person. I pulled the service records from P/O and went to NAPPY to get the filters. The counter guy handed me 2 spin ons like my MC8 uses, But IIRC this C3 has a large white metal canister filter with a drain on the bottom, located beside the A/C compressor. I figured that this was the only filter and it would just be a paper element. Does it also have primary and secondary filters? Whats the procedure for service on the big bannister filter?
Thanks a lot, Chuck
At some point, not sure of the year or model, MCI started using magnetic proximity switches on all of the doors.
Circular, a little larger than a quarter.
With a partner, check for voltage at the sensors, check for physical clearance, a bent door edge will put it too far away, and, ultimately, start shorting the sensors. Try not to pierce wires, that will give you grief with corrosion down the road...
