new generator help
new generator help
Started by ruthi, June 22, 2010, 04:26:23 PM
ruthi
Anyone know of a place to buy a 10 k generator in Memphis, Tn?
southeast most of the time.
Depends on what you want try Nixon or Mid South Cummins there is also a place in Hendersonville that sell and services generators
ruthi
We have had a lot of trouble with the power tech we have and it now has some major issues. Would like to find a good one that will hold up to a lot of use. We are in Memphis right now, and it is too hot to be with out. Trying to find one in the area.
ruthi
Really wanted to buy one from engine power source, but we are pretty desperate too in this heat.
robertglines1
rental unit plugged into your shore power???till you get one....stay cool
Ruthi, just my 2 cents worth but the way you travel and work I would buy a Onan they have the best service network of any on the market and they are not a bad generator plus most Cummins dealers are open till midnight everyday with a good parts department for Onans
James77MCI8
 CUMMINS MID-SOUTH, LLC
3770 South Perkins Road
Memphis, TENNESSEE 38118
Phone: (901) 577-0600
Try these people Ruthi.
77 MCI 8
8V-71 4 spd
plyonsMC9
Hi Ruthi - please continue to keep us posted if you can!!  Any luck w/ the suggestion by James77MCI8 and luvrbus on the Onan/ cummins?
Kind Regards, Phil
ruthi
Thank you for the suggestions, Ken is trying to locate one as we speak. I will let yall know.
ruthi
Oh, and just a side note, to stick the knife in deeper, one of the air conditioners went out. Ken knows what is wrong with it, but no one will sell him parts without a liscense. :-\
Quote from: ruthi on June 23, 2010, 08:11:02 AM
Just tell them he is Nick Badame! ;D
When it rains it pours huh. Sure hope you can get it all worked out before winter! ;)
ruthi
You are right. Winter we will be in the new bus, we will see how that goes. WE dont have cold that bad, but we sure have the heat. Temperature rises real fast when the power goes out.
robertglines1
are you going to be there rest of week?if so what you need....diesel gen set or gas....parts?
Ruthi,
We are minutes off exit 108 on I-40 if there is anything we can help with. It's a busy time for us, but I'll do what I can.
Also Hendersonville is a suburb of Nashville. FWIW
ruthi
Thanks for the offers. I dont know what is needed. We have a power tech, it is leaking oil like crazy, and every so often it blows smoke and bogs down. Timing sucks, we are in the process of painting new bus, lots of money, and the central air in the house just went out, and had to replace, again, big money, and now this, oyyyy. Roof air needs a part.  Wont be home til not this sat. but the next saturday. Dont know if it will keep running. I thought it was a 10k but hubby says it s a 12k powertech. Probably needs parts.
Any one has ideas can call him at four 78 four 56 three 3 56.
