Prevost Shorty Update
Started by chuckd, June 18, 2010, 06:26:56 AM
chuckd
Just a quick update, because I haven't made a lot of progress.  Seems like a tare (tear) (sp) more apart than I fix.
Installing a Rostra Cruise control, still in progress, think I have a bad speed sensor on the drive shaft, going to replace same.  Install other than a minor hickup is going well.
Replaced the heat exchangers and have made sure that we can get at them without major surgery on cabinets and entertainment center.  Had to modify the exchangers themselves in order to accomplish the above.  They work and do not leak any more!
Have roughed in location for LCD TV and sound bar, the sound bar is a poor mans substitute for a full 5.1 system and seems to work well in the bus.  Has a wireless sub woofer which makes for an easy install.
Replaced the black and white back up camera with a color camera and LCD screen.
Replaced leaking water pump.
Fixed a leaking joint in the water system.
Went nuts trying to figure out why the water direct from the hose would not work, finally called the PO, and found the valves that were causing the issue - about 4 freakin hours of frustration before the call.
Going to Grand Marais Mn this weekend to use the coach for the first time!
Have cracked tile in the shower causing a leak, separate post for that topic.
Chuck
Pictures would be great, thanks :)
DaveG
So is this a shorty bus or just a shorty update?
