Another antifreeze question
Started by sweeney153, May 22, 2010, 08:13:56 AM
sweeney153
I had to remove a hose for the repairs and lost about4-5 gallons of coolent.
I don't want to put the old stuff back in so I went to NAPA to get anti freeze.
They tell me what I need is
Zerex® ORIGINAL RTU
ANTIFREEZE COOLANT ZXRU1
COMPOSITION/INFORMATION ON INGREDIENTS
Components CAS-No. Concentration
ETHYLENE GLYCOL 107-21-1 >=50-<60%
DIETHYLENE GLYCOL 111-46
I just wanted to make sure before I put it in.
Thanks again
Kevin
Sweeney153
Warwick NY
1964 4106-2703 8V71 Spicer 4 speed
Which engine do you have?  A Detroit 6-71 doesn't really matter that much since it have dry cylinder liners.  But if you have the Cummins NH220 with its' wet cylinder liners-it is critical to preventing cylinder liner pitting and eventually cylinder liner failure.  Good Luck, TomC
sweeney153
Warwick NY
I use the plain ole green stuff from WM in my 671.
What Gus said.  Good Luck, TomC
