FYI: 4106 Radiator Fans 6 blades vs. 8
Started by OneLapper, May 13, 2010, 07:12:52 PM
OneLapper
These fans came out of two different 1964 PD4106s that happen to be only 102 serial numbers apart, both delivered new to Connecticut, both spent their lives in New England.
I didn't even notice the difference until they were side by side!!
My bus had the 8 blade fan, and I've never seen temps over 190 degrees.  Interesting!
OneLapper
1964 PD4106-2853
www.markdavia.com
zubzub
unless you cleaned up the 8 blade I would guess the 8 is an upgrade from stock...maybe installed later?
chris4905
Anybody know why the fan blades have a "notch" on all of the blade tips ??????
Chris & Cheryl Christensen
Ex-Bus Owners
Eagle, Idaho
zubzub
seems like a simple way to reduce blade flex/tune the blade.  As the tips will turn faster than the middle. notching them stops them from distorting as a result of trying to move more air than the center?  Maybe equalizing the flow over the entire fan area reduces turbulance/increases flow? 2 guesses from someone who has no idea.
OneLapper
Quote from: zubzub on May 15, 2010, 01:10:30 AM
The notches in the fan allow it to fit closer to the core of the radiator.
Here's a pictures of the radiator and shroud.
OneLapper
1964 PD4106-2853
www.markdavia.com
Mrbill4108
Anyone have one of those 8 bladed fans they want to get rid of/sell/swap?
Mrbillh
79 GMC 4108A
S/N 228
Florida Space Coast
Lee Bradley
The title reminds me of the joke about the guy picking up a pizza. The pizza man asked if he wanted it cut into six or eight slices after a moments thought the customer said better make it six I'm not hungry enough for eight.  Sorry back to your regularly scheduled discussion.
Barn Owl
Two ways to cool:
1. More fan blades. Cheaper and easiest of the two solutions. If you look at the charts for radiators, you see they rate their cooling by graph according to how much air flows over them. Down side is they eat hp/fuel for lunch.
2. Bigger radiator. Very costly, but the better of the two solutions if you can afford the upfront cost.
The 4106 came with a four core radiator, but there is enough room there to add three more, for a total of seven. If you ever re-core I would recommend the upgrade. If you ever put in an auto with the oil/water cooler you will probably not have a choice.
