Anyone running Alcoa DuraBright rims
Started by Zeroclearance, April 24, 2010, 08:03:21 PM
Zeroclearance
I'm looking to upgrade my steers to 22.5 X 10.5..    I'm tired of polishing the rims..
I don't run Alcoa's but do the Accuride with Accu-Shield I am sure Alcoa's uses the same process a clear powder acrylic coating so far so good  just be sure to dry they water spot.
Sean
We have the Dura-Brights and have been very happy with them.
How much weight are you carrying up front that you want to go to the extra-wide rims?  That's gonna make your tires real spendy, and you'll need more muscle to steer at low speeds.  It might also increase your turning radius.  FWIW.
robertglines1
FWIW :365's on front of new prevost..just noticed when visiting featherlight..I am getting ready to buy rims for new project so am very intrested in reply..Live in midwest and plan to avoid much road salt mixture..
Sean, the 45 foot Prevost does carry a lot of weight on the front my friends 2009 H-45 uses the 365/70 0n the front and tag we weighed his front and it was at 17,710 lbs
Zeroclearance
Bob, I got a quote of $2,977 from Prevost to supply the new update>  Michelins, Alcoa's and hardware.   $290 for new Koni's..
I have done some checking around>  A friend works as a purchase agent at Pacar and he mentioned that Alcoa's has just implemented a 200 unit minimum order guideline.    Prevost has the rims instock but it seems that we can't get them wholesale due to supply.
Sean,  I haven't parked my steer axle on the scales.   I am running 24.5 x 8.25 rated at 7200lbs right now.   Everytime I talk with Prevost they suggest the "upgrade"..
Sean
I would weight it.  Prevost has an axe to grind.
If you go to 22.5x9 all the way around, you can use 315/80 on every wheel position, and the Alcoa's are widely available in that size.  Might even find take-offs.  I'm guessing if you are on 8.25" wheels today, then the 9" ones will be more than adequate for your needs.  315s on 9" rims will support axle weights up to 18,000 or so on 75mph tires, and 20,000 or more on speed-limited tires.
FWIW, we upgraded from 8.25" to 9" rims explicitly to "upgrade" to 315/80 tires.  For our weights, the 315s were overkill, but I wanted to run lower pressure for better off-road traction, and have the larger contact patch.  It turned out to be a mistake; not only did the 315s cost a whole lot more, but we got less wear out of them, the tires rubbed the wheel wells in tight turns, and steering effort went way up.  We're back on 12R22.5 tires now.  I have a compressor and air chuck on board, so we can always drop the pressure for sand or whatever.
JMO and YMMV, as they say.
Zeroclearance
Sean, I will look up the weight limits for the Alcoa rims @ 9.00"..   However, the "axe" that Prevost wants is 365's steer and tag.    Aren't these the same tires combinations that cement trucks run?
Sean
Cement trucks indeed use super-singles on the steer.  Remember, though, that these guys are routinely driving off-road into soft stuff, so the lower pressures are imperative.
rusty
I am looking for some help with terms about tires. I thought super singles was a tire that took the place of dual tires at a wheel end. A wide base tire was used on off road construction equipment in the steer position. There are some tires (425/65r 22.5) that can be used on the steer axle that are 17.8 inches wide and require a 14 inch rim the same as a super single, but they call them wide base tires.Am I missing something.
Thank You Wayne
Sean
Quote from: rusty on April 25, 2010, 04:14:32 PM
I am looking for some help with terms about tires. I thought super singles was a tire that took the place of dual tires at a wheel end. A wide base tire was used on off road construction equipment in the steer position. There are some tires (425/65r 22.5) that can be used on the steer axle that are 17.8 inches wide and require a 14 inch rim the same as a super single, but they call them wide base tires. ...
Wayne,
I don't think there has been any standardization of these terms by the industry.  I have heard the term super-single used to describe both -- the ones that replace duals, and the ones that are extra-wide for single applications.  However, if you prefer the term "wide base" to describe the extra-wide tires for single applications, I'll use that instead.
To be clear, I was referring to the extra-wides that fit on 10.5" rims (or the ones for 14" rims) that Prevost is now fitting to all dual-slide conversion shells.  They are using these on steer and tag axles, and conventional 9", 15° offset rims on the drivers.
One of the issues I have with this, and I would have the same issue with using the dual-replacement style super-singles on the drivers, is that it prevents you from interchanging wheels in an emergency.  For example, on many Prevosts, you can lift the tag.  So a driver failure could be worked around temporarily by swapping it with one of the tags, then lifting that axle.
For the rest of us (without liftable tags, or with no tags), a drive wheel could be swapped for a failed steer tire in a pinch.  That would leave the drive axle one tire short, but at least you could limp someplace.
So I have a personal bias toward having the same size wheels and tires in all 8 (or 6) positions, but, again, JMO.
rusty
Sean, Thank You for your reply. I will stay with the term supersingle for the replacement of duals with one tire. And the larger steer tires a wide base tire. I understand your concern for the need to move tires around to help in emergencies.
Thank You Wayne
Wayne, your going to make those babies work on the 15 no matter what they are called  lol
rusty
Yes. I don't share Sean's concerns. If you look at trucks about 20 percent are now running the supersingles and more every day. They are becoming common enough that finding a replacement should not be a problem. Also I have 80,000 on my 05 and have never had a flat. That doesn't mean I can't have one but if I do I will have to wait until someone brings me one. We will see how it works out.
Thank You Wayne
NEO/Russ
Dura brite rims use a patented process, not clearcoat.  I've been researching rims for my truck and according to the local Truck Pro who used to sell Alcoa's they had quite a few that turned color, but then again - they used to sell Alcoa's.  I've been looking at Forgitron, they don't do the 9", but they do the standard 8.25's and the workmanship looks real good.  They also are much more reasonable than Alcoa's http://www.forgitron.com/index.php/products/commercial-truck-wheels . I talked to them at MATS in Louisville last month about other treatments, and they don't recommend the clear coats because the heat cycle to clearcoat can reduce the rim temper.  I've had Alcoa's polished and buffed so I don't have to and finding someone to do it for about $35-40 is pretty common here in TN.
The SuperSingles are becoming much more common for fleet fuel savings.  And the California regs for new trucks into and out of ports is calling for improved fuel mileage and that is part of it so you will be seeing them much more.  Don't run if you don't have tags.  If you loose one you will be in major hot water if you don't have a tag to bring it down in speed and stop.
Well no longer a bus nut, but over the years I learned a lot here and still come back to see what I can apply to the conversion of my KW T2000 for hauling my Teton fifth wheeler.
