Cooling fan drive gasket?
Started by brando4905, April 05, 2010, 05:57:47 AM
brando4905
Just got back from first trip with "new to me engine"! Trip totaled 1000mi, blew out over 2 gallons of oil through fan drive gasket, other than that it was a successful trip.
The leak is at the gasket that mates the fan drive to engine. I can't seem to locate a new gasket, anyone have a part number? Bus is a 4905, engine is 8v71.
Brandon
1980 GMC H8H-649  8V71/V730 Marion,NC
"The highway is for gamblers, better use your sense" -Dylan
larryh
you need to make your own gasket if it is the gasket. I just had to replace the seal again in mine as it had worked out and stuck to the hub for the fan and was turning inside the housing and pumped out over 3 gallons in 1000 miles
Savvy ponderable:
A cowboy's only afraid of two things:
havin' ta walk,
and the love of a good woman.
"This posting was generated using an environmentally friendly, self contained flatulence generator, therefore no fossils or neutrons were harmed in the creation of this posting.
Quartzsite,
LUKE at US COACH
Hi Brandon & Folks:
We have the gasket you need, in stock.  You can reach us toll free at: 1-888-262-2434.
I Hope this HELPS!!!  Happy & SAFE!!! Bussin' to All.
LUKE at US COACH
wildbob24
Brandon,
If it's the gasket between the fan drive and the oil pump it's #2386776. Mohawk is showing 446 on hand at $1.05 ea.
If it's the gasket between the oil pump and the block It's # 5121714. Mohawk is showing 145 on hand at $4.40 ea.
Luke posted while I was typing this. He's certainly a good source for parts, as well.
Bob
P8M4905A-1308, 8V71 w/V730
Custom Coach Conversion
PD4106-2546, 8V71, 4sp
Greenville, GA
brando4905
Thanks for the info guys!
When this new engine was put in, the hydraulic fan was replaced with my direct drive fan. Homemade gasket was used in this swap and didn't work. Hoping the right gasket will do the job.
