Converting to spin-on fuel filters
Started by Fredward, March 15, 2010, 11:31:24 AM
Fredward
Does anybody know the NAPA part number for the spin on filter base that I need to convert my 8V71 MC-5 from canister type fuel filters to spin on? I'm getting ready to head out in a few weeks and while I do my annual filter change, I figure I might as well go to the spin on style. Looks like I can just bolt them right on where the canister ones are located now. I will try cross referencing the spin on numbers from the cartridge style and then see what the correct base is.
Are primary and secondary the same base?
FRed
Fred Thomson
Fred,
5148023 for primary
5148171 for secondary  DD numbers Napa can cross it over
JohnEd
I will go out on a limb here and say that the the reason toconvert is that cannister is more trouble to change.  How do they compare in terms of filter area, cost, and does the cannister make priming any easier?
bryanhes
In talking to a bus charter owner he said he preferred the cartridge type. Reason being that you could drain easily to check for water in the fuel. I know they make the spin on with a drain valve but have heard they are a bit more expensive. I just opted to keep the cartridge for now unless there is a bigger benefit to spin on I am unaware of. Which could be  :-\
Bryan
Fredward
I've got an electric fuel pump plumbed in for priming so the only reason to get away from the canisters for me is the mess. I helped a buddy bring an Eagle home last fall and we had to change filters a few times and the spin ons are way easier than the canisters and easy to prime because you just fill them up and screw them on.
I'll see how much it all costs at NAPA. I've got the bus sitting in the shop right now and figured it would be an easy project with measureable benefit..........
Of course, if it ain't broke; why fix it.................   Fred
Fred Thomson
James77MCI8
Spin ons are more readily available at truck stops.
77 MCI 8
8V-71 4 spd
rv_safetyman
Fred, I would sure consider the Fuel Pro 382 (https://www.davcotec.com/DFP-_fp382.htm).  Good water separator, you can see when to change filter, self priming, etc.  Most new trucks have them in place of the two spin-on filters.  You can get them at a DD dealer, truck dealer and the E place.  It is a bit pricey, but I would not consider going back to spin-on filters.
Jim Shepherd
Evergreen, CO
Lin
Jim.
When you say they use it instead of two spin-ons do you mean it replaces both the primary and secondary filters?  How easy are they to install?
rv_safetyman
Lin, the recommended installation is to eliminate both filters and plumb the outlet of the filter directly to the pump and then the outlet of the pump directly to the injector inlet connection.  Very easy to install if you can find a location.  Two bolt and then the hose connections.  They recommend installing the filter above the fuel level in the tank.  That always seemed strange to me, but it works great.
Jim Shepherd
Evergreen, CO
I didn't realize there were internal canister type filters?
My 4104 primary filter is a stacked disc type which only requires flushing out with solvent and reinstalling, a very neat setup and it has a drain valve. It is a bit messier than a spin on, but not much.
My secondary is a spin on, wish it was also a stacked disc. I think the original was.
dougyes
We changed all our buses to Fuel Pro. They are stock on the new MCI's.
Lin
So in the installation, you are basically just bypassing the secondary filter.  The assumption then would be that one pass through it is as good as two passes with standard filter.
rv_safetyman
Lin, probably words, but you eliminate both filters.  You may be saying that you bypass the secondary filter in terms of plumbing, but both filters are gone.
The Fuel Pro, as dougyes, noted are pretty much standard for most big diesel engines from what I can tell.
It is neat to be able to see the quality of your fuel and be able to observe when a filter change is needed.  Pretty easy to change the filter as well.  Almost no chance to loose the prime.
Jim Shepherd
Evergreen, CO
gumpy
Quote from: Fredward on March 15, 2010, 11:31:24 AM
FRed
Fred,
Before you go spending a bunch of money on those filter bases, you might want to come see me.  I think I still have the set that I took off my bus, and maybe even a few filters to go with them.  They should bolt right up to your 5.
I'll make you are VERY good deal on them.   ::)
craig
JackConrad
The FuelPro is also a great diagnostic tool. If you are loosing power, look at the filter. If the fuel is up to the "change filter" line, you have a plugged filter, if the fuel in the clear bowl in black, you have algae in your fuel, if you see air bubbels, you have a leak and are sucking air in the supply line, if no fuel in bowl  you have a blockage or are out of fuel.  Jack
